土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ Ols房屋/ J. Mayer H.建筑师/Ols House / J. Mayer H. Architects
发布于:2015-09-30 22:29:30 来自:建筑设计/公共建筑设计 [复制转发]
概念:
新房子在斯图加特附近的一片土地上,在一个能看到山谷景色的山坡上。业主想要一个能够将这种景色带入到生活中,甚至是建筑内部的新房屋。房屋处在一个有着常规发展的住宅区内,大部分可以追溯到20世纪60年代。
Concept:
The new house is on a plot of land near Stuttgart, on a hillside with a generous view of the valley. The owners wanted a new home that would bring this view to life even inside of the building. The house is in a residential area with conventional developments, most of which date from the 1960s.
这个新的4人房屋被分为有着入口区,杂物间和水疗中心的底层和包含着客厅,餐厅和厨房区域的开放流动的二层。人们可以从全高玻璃自由的看到山谷的景色,从露台俯瞰花园区。楼上是睡眠区,更衣室和浴室。中央设计着一个连接着所有三层楼的雕塑楼梯。
The new, 4-person family home is divided into an elevated ground floor with entrance area, utility room and spa, and a second floor with an open, flowing floor plan containing the living, dining and kitchen areas. Full-height glazing provides a free view of the valley and terrace looking over the garden area. Upstairs are the sleeping areas, dressing rooms and bathrooms. The central design element is a sculptural staircase that connects all three levels.
结构:
房屋被建为钢筋混凝土的结构。表面包含着一个隔热的复合系统,和一个铝及玻璃幕墙。板条和抗强光单提供了集成的太阳防护,保护其免受热量的损害。里面的所有轻质隔墙都是由石膏板建造而成的。地面是熨平板的无缝层。有着深凹进去的阳台的屋顶是用预风化的锌板覆层建造而成的,并配有太阳能电池板。室外需要铺砌的区域用方格图案铺成。
Construction:
The house was built as a reinforced concrete construction. The facade consists of one heat-insulating compound system and an aluminum and glass facade. Slats and anti-glare sheeting provide integrated sun protection, protecting it against heat. All of the lightweight partition walls inside are made of drywall. The floor is a seamless layer of screed. The roof with the deep, recessed balcony was built with pre-weathered zinc plate cladding and is fitted with solar panels. Outdoor paved areas were realized as tartan surfaces.
Floor Plans 平面图
Floor Plans 平面图
Floor Plans 平面图
Floor Plans 平面图
Floor Plans 平面图
Elevations 立视图
Elevations 立视图
Elevations 立视图
Elevations 立视图
全部回复(5 )
  • cmlhjcfs
    cmlhjcfs 沙发
    非常有特色的建筑,谢谢分享。
    2016-10-13 23:57:13
  • 学习设计方案
    感谢分享,值得学习
    2015-10-13 12:26:13
公共建筑设计
51.18 万条内容 · 448 人订阅
复式阁楼的内部修复/ Cavaa 建筑事务所/Interior Restoration of an Attic Duplex ...
该项目开始的前提是城市里位于公园前面的一套大的复式公寓被分成两套住宅,以便更好地适应家庭目前的需求。这套住宅拥有豪宅的所有元素和氛围,所以第一眼望去,游客就可以感受到这个家的豪华。这个计提案的挑战在于要恢复这个宏伟空间的同时,又要保持其原有的特性。因此,该提案的目的是能够确保保护好丰富的原始空间的所有元素,同时得到新的建筑结构:在新的生活形式和遗产的继承之间建立良好的对话关系。
