土木在线论坛 \ 装修设计 \ 家装设计 \ 学生室内设计/ Ruetemple/Interior for Students / Ruetemple
发布于:2015-09-28 13:03:28 来自:装修设计/家装设计 [复制转发]
顾客的意愿:两个学生的房间:为哥哥和妹妹提供一个工作区和娱乐区。
Wishes of the customer: to design a room for two students: a brother and a sister, provide an area for work and recreation area.
概念:工作区固定,娱乐区移动,可以根据立方体变形体改变外形。多立方体建筑包括三个移动模块。根据模块位置的改变,将卧室改变成一间客厅、一间舒适的休闲室、一间客厅、一个单独的房间或一间带一张或两张床的卧室—— 可变换无数。
The concept: work area is fixed, recreation area is dynamic, it can be changed due to the cube-transformer. Cube consists of three mobile modules. Depending on the positions of the modules cube transforms the room into a living room, a cozy chill-out room, a parlor, a room within a room or a bedroom with one or two beds – transformations are numerous.
大梁之间有一个网格吊床。你可以在此躺下仰望天空,或读一本书。
Between beams there are grid hammocks on which you can lie down and look up at the sky or read a book.
该项目用于“屋舍解决方案”( NTV广播公司)
The project is made for << COTTAGE SOLUTION >> (“ NTV Broadcasting Company ”)
Floor Plan 一层平面图
Axon 轴测图
Axon 轴测图
Axon 轴测图
Axon 轴测图
Details 细节图
Details 细节图
Details 细节图
Elevation 立体图
Sections 截面图
Sections 截面图
家装设计
22.34 万条内容 · 392 人订阅
我的作品--星汇半岛住宅空间设计
最近做的室内设计作品.
