土木在线论坛 \ 装修设计 \ 家装设计 \ 庐师山俱乐部/方体空间/The Lushi Hill Club / Atelier Fronti
发布于:2015-09-20 21:43:20 来自:装修设计/家装设计 [复制转发]
建筑:方体空间
地点:中国北京
面积:1600平米
照片:方体空间
Architects: Atelier Fronti
Area: 1600.0 sqm
Photographs: Courtesy of Atelier Fronti
俱乐部位于北极西郊外住宅区,这里是52座别墅的聚集区域。这是建筑面积1600平米,包括咖啡厅,会议室,四个访客室的三层楼房屋。俱乐部的三层大厅由玻璃幕墙与外界隔开。这座建筑的主题在营造室内室外物体的视觉关系。
This club is located in a residential area in the west outskirts of Beijing and is an activity site for 52 villas there. The building area is 1600m2. This building includes three floors and consists of coffee halls, meeting rooms and four guest rooms. A three-floor hall at the entrance of the club is separated from the out by a whole glass curtain wall. The main point of this building is the vesion relations between the outdoor and indoor objects.
俱乐部面对整个区域保护老树中央绿地区。通往二楼的坡道让用户透过玻璃墙感受室外风景。俱乐部遭受了许多施工上的难点。3.6米宽,3.6米高的门在设计和决策阶段都遇到了困难。11米高的玻璃幕墙悬在西侧。 上部玻璃墙有七米高,根据标准进行钢化,但钢化炉只能烧制6.8米的钢化玻璃。因此玻璃幕墙无意之中是在挑战这个时代工艺的极限。
The club faces to the center green land of the whole area which reserves old trees with nice sceneries. Thus a slope connected to F2 in the hall is designed to enable people to experience the sceneries outside the glass wall. There are many construction difficulties of this club. The 3.6m-wide and 3.6m-high door at the entrance experienced difficulty in designing and making phase. The 11m-high. glass wall is suspended in the west. The upper glass wall is 7m high and need to be tempered according to the standard, but only 6.8m tempered glass can be produced by the tempering furnace, thus the curtain wall challenges the limit of this era unintenionally.
First Floor Plan一层平面
Second Floor Plan二层平面
Third Floor Plan三层平面
Roof Floor Plan屋顶平面
Section剖面
North Elevation北立面
West Elevation西立面
South Elevation南立面
East Elevation东立面
  • zgbjws
    zgbjws 沙发
    这是 中国工程师设计的吗
    2015-09-21 15:49:21
  • yuyanhui63
    yuyanhui63 板凳
    很是感激楼主的 无私奉献
    2015-09-21 04:44:21
家装设计
22.34 万条内容 · 392 人订阅
小空间大智慧——瑞典极小公寓设计
不只是日本人擅长在地窄人稠的都会区充分利用小空间做出最佳应用,其实每个国家都会有相同的需求。 这间位于瑞典斯德哥尔摩的小公寓充分利用设计与空间运用,让一个单纯的小套房也能有大房子的舒适。 相较于之前我们介绍过的“简洁有型的品味两房小公寓”,这间明显的空间更小,大改只可算是一间套房。
