土木在线论坛 \ 装修设计 \ 家装设计 \ 现代家庭住房/ Dennis Gibbens Architects建筑事务所/Modern Family Home / Dennis...
发布于:2015-09-20 19:54:20 来自:装修设计/家装设计 [复制转发]
该项目位于加利福尼亚州的Venice,共有两层楼,12000平方英尺,包括5000平方英尺的单一家庭住宅以及客房。该住宅整体面积对于目前洛杉矶来讲已经足够大了,大小正合适的一个年轻的四口之家。
This project consists of a two-story, 5,000-square-foot single family residence and guest house on a 12,000-square-foot property in Venice, California. The property is large for this section of Los Angeles, making it nicely sized for a young family of four.
一楼规划为一个长条的形状,有一个开放的公共房间,全部朝向西半部。客厅是一个双层楼高的空间。外部空间包括前花园、私家花园、外部覆盖的区域和不同的混凝土桥面、一个运动场、一个游泳池和水疗中心。
The first floor plan is in the shape of a long bar and has an open arrangement of public rooms all looking on to the western half of the property. The living room is a double-height space. The exterior areas are comprised of a front garden, a private garden, an exterior covered area and various concrete deck areas, a sports court, and a swimming pool and spa.
二楼T形的主屋包含了一间主人的大套房和两间孩子的卧室、一间洗衣房、一间办公室和一间灯火管制的大媒体室。客房与游泳池在一条轴线上,位于南部边缘。
The T-shaped second floor of the main house contains a large master suite and two children’s bedrooms, a laundry room, an office and a large black-out media room. A guest house pool house is situated at the south end of the property on axis with the pool.
主要的外部材料是白色的粉刷、玻璃和金属面板。屋顶上的光生伏打板为住宅提供一部分的电力。
The main exterior materials are white stucco, glass and metal panel. Photo-voltaic panels on the roof provide a portion of the electricity for the residence.
Gorund Floor Plan 底层平面图
Second Floor Plan 二楼平面图
North East Elevation 东北立体图
North West Elevation 西北立体图
South East Elevation 东南立体图
South West Elevation 西南立体图
Site Plan 场地平面图
Section 截面图
Section 截面图
Section 截面图
Section 截面图
  • zgbjws
    zgbjws 沙发
    谢谢 楼主分享
    2015-09-21 15:44:21
  • yuyanhui63
    yuyanhui63 板凳
    很是感激楼主的 无私奉献
    2015-09-21 04:46:21
家装设计
22.34 万条内容 · 392 人订阅
复式阁楼的内部修复/ Cavaa 建筑事务所/Interior Restoration of an Attic Duplex ...
该项目开始的前提是城市里位于公园前面的一套大的复式公寓被分成两套住宅,以便更好地适应家庭目前的需求。这套住宅拥有豪宅的所有元素和氛围,所以第一眼望去,游客就可以感受到这个家的豪华。这个计提案的挑战在于要恢复这个宏伟空间的同时,又要保持其原有的特性。因此,该提案的目的是能够确保保护好丰富的原始空间的所有元素,同时得到新的建筑结构:在新的生活形式和遗产的继承之间建立良好的对话关系。
