土木在线论坛 \ 园林景观 \ 园林景观实景 \ 克雷泰伊”高卷式”郊区车站/ AREP的实景图
发布于:2015-09-17 20:36:17 来自:园林景观/园林景观实景 [复制转发]
? J. Glay
克雷泰伊•蓬巴杜站是在巴黎东南部郊区的克雷泰伊市创建多模式交通枢纽这个更广泛的计划的一部分。
From the architect. The Créteil-Pompadour station is part a wider programme to create a multi-modal transport hub in the Créteil municipality on the south-east outskirts of Paris.
? J. Glay
这就要求对场地的重大重组计划,其中包括:
- 修改道路布局,以此来改善公共交通工具之间的连接?
- 铁路基础设施的改善工作,以提高法国国营铁路公司的运输产品,
- AREP委托创建一个车站建筑和一个行人天桥来连接车站与公交车站。
This calls for a major reorganization of the site that includes:
- modifications to road layout to improve connections between public transport modes?
- rail infrastructure work to boost SNCF’s transport offering,
- the creation of a station building and a footbridge connecting the station with the bus station, commissioned from AREP.
? J. Glay
? J. Glay
为了在这个狭小的地块中腾出尽可能多的地面空间,避免由轨道尺寸施加的限制,并解决网站的潜在洪灾风险,该站的主体是建立在高出地面近十米的平台上面。只有位于公交车转弯面积区域的小型技术建设可以从站前广场通行。
In order to free up as much ground space as possible in this cramped site, sidestep the limitations imposed by track dimensions, and address the site’s potential flooding risk, the main volume of the station is built on stilts rising to a height of almost ten metres above ground level. Only the small technical building located in the bus turning area is accessible from the station forecourt.
Master Plan/总平面图
? J. Glay
因此,所有为乘客提供的服务均位于连接天桥上面,天桥同时连接通往RER线火车D月台的入口平台与两个巴士路网的专用通道。
Consequently, all passenger service provision is located at the level of the connecting footbridge linking the access platform to the RER Line D train platforms with the dedicated lanes of the two bus networks.
? J. Glay
该建筑是用水泥填充的金属柱,金属柱的格栅形式体现了大型跨梁模式,旨在创建一个有额外增加旅客流量能力的乘客大厅以及所有配套场所的空间。
The building is structured using cement-filled metal poles whose grid reflects the patterns of the large-section cross-beams and designed to create the space for a passenger hall with extra capacity for increases in passenger flows, together with all ancillary premises.
? J. Glay
所用材料的类型被仔细地限定,材料包括木材、金属、聚碳酸酯等。随着年龄将变为灰色的浅色木质外墙,为“悬挂”空间提供了视觉上的和谐。与之呼应的是在相邻的小树林间不均匀间隔的纤细的树干。
The range of materials used was deliberately restricted, and comprises wood, metal, and polycarbonate. The light-coloured wooden fa?ades, which will age to grey, provide a visual unity for the “hanging” space with its unevenly-spaced, inclined supports that echo the slender tree trunks in the adjacent small wood.
? J. Glay
? J. Glay
? J. Glay
  • 园林居士
    园林居士 沙发
    谢谢提供
    2019-07-25 06:48:25
  • a312437470
    a312437470 板凳
    外国的设计挺大胆的 其实为什么要走上面呢 走下面不是一样的么
    2015-09-18 12:37:18
园林景观实景
37.75 万条内容 · 296 人订阅
Iceland 1: Landscape 冰岛景观实景图
.pcb{margin-right:0} Iceland 1: Landscape 冰岛景观1Mudpot - Krafla, Iceland (Photographer: Scudsone/Flickr) The earth moves. Two centimeters per year. The eastern half of the island moves one way, the western half the other way. Iceland not only suffers from risky banking, the country is built on two tectonic plates creating an ever growing space in-between.
