Timur Shabaev © OMA
当代艺术车库博物馆是由上世纪六十年代时期兴建的Vremena Goda餐馆改建而来,二十年来这个水泥建筑一直被荒废。OMA工作室设计了包括两层的展览画廊、儿童娱乐中心、商店、咖啡厅、讲堂、办公室和屋顶露台在内的5,400平方米的空间。设计保留了苏联时代的元素,包括马赛克墙、瓷片和砖,同时加入了一系列创新的建筑设计和眼光长远的设备。 From the architect. Garage Museum of Contemporary Art is a renovation of the 1960s Vremena Goda (Seasons of the Year) restaurant, a prefabricated concrete pavilion which has been derelict for more than two decades. OMA’s design for the 5,400 m2 building includes exhibition galleries on two levels, a creative center for children, shop, café, auditorium, offices, and roof terrace. The design preserves original Soviet-era elements, including a mosaic wall, tiles, and brick, while incorporating a range of innovative architectural and curatorial devices.
Yuri Palmin © Garage Museum of Contemporary Art
David X Prutting © BFA.com
该博物馆于2008年在Konstantin Melnikov设计的Bakhmetievsky巴士车库基础上建成。车库博物馆从莫斯科北部半工业化区搬到了城市最知名的公共场所——高尔基公园,势必吸引更广泛和更多的观众。 Garage Museum of Contemporary Art was founded in 2008 at the Konstantin Melnikov designed Bakhmetievsky Bus Garage. Relocating from a semi-industrial neighborhood in the north of Moscow to one of the city’s best known public spaces (Gorky Park), Garage will address a much larger and diversified audience.
自上世纪九十年代被荒废以来,建筑经历了风霜日晒,曾是高尔基公园最受欢迎的景点之一的前Vremena Goda餐馆也变成了一座没有外墙的废墟。即使遭受了破坏,它仍保留了苏维埃时期的集体气氛:一座由瓷砖、马赛克和砖装饰的严肃的公共空间。 Exposed to snow, rain, and sun since it was abandoned in the 1990s, the former Vremena Goda restaurant – once a popular destination in Gorky Park – has become a ruin without facades. Even as a ruin it preserves the “collective” aura of the Soviet era: it is a sober public space adorned with tiles, mosaics and bricks.
Original Situation/场地原状
建筑本身有两层未加防护的开放空间,围绕两个圆和服务中心,将被设计成展馆。博物馆项目根据原本的空间和结构占了三层。在博物馆东北角有更多围绕着展馆核心的零散空间,主要用于教育和研究。西南角的大面积开放空间被用于展览、项目和集体活动。 The building offers two levels of unobstructed open space that will be dedicated to exhibitions, organized around two circulation and service cores. museum programs occupy three levels, adapting to spatial and structural possibilities of the existing structure. The more fragmented spaces in the North Eastern part of the pavilion surrounding the main core primarily accommodate education and research programs. The large open spaces in the South Western part are dedicated to exhibitions, projects and events.
Exhibition Concept/展厅概念图
建筑在随处可见的‘白色立方’后面,为艺术展览区划分出大面积的室内空间,类似带铰链的白色墙面可收折于屋顶这样的创意设计,为空间提供了创新和发展的可能性。在旧墙保留着原本的砖块和绿瓷贴片外观的同时,白色立方为展览提供了预留空间。 The building offers a wide range of interior conditions for the exhibition of art beyond the ubiquitous “white cube” and provides innovative curatorial possibilities, such as hinged white walls that can be folded down from the ceiling. They provide an instant white cube when an exhibition demands a more neutral environment, while the existing walls retain their brick and green tile cladding.
Model/建筑模型
上层9×11米的入口为展厅创造了一个双层高(10米)的空间,让特大体积的雕塑在此展示。低层的公共走廊连接书店、多媒体图书馆、讲堂和一个咖啡厅。被设想为以苏维埃时期家具装饰的日常起居室。 A 9×11-metre opening in the floor of the upper level creates a double height space (10 metres) for the lobby, allowing extra-large sculptures to be displayed. A public loop on the lower level will connect the bookshop, mediatheque, auditorium and a café, which is envisioned as an informal living room with Soviet era furniture.
Ground Level Plan/底层平面图
已有的水泥结构被双层聚碳酸酯外墙围了起来,用来容纳大规模的建筑通风设备,让展览空间保持绰余。外墙从地面抬高2.25米,以便能让一楼看到室外的景观。 The existing concrete structure is enclosed with a new translucent double layer polycarbonate façade that will accommodate a large portion of the building’s ventilation equipment, allowing the exhibition spaces to remain free. The facade is lifted 2.25 metres from the ground in order to visually reconnect the pavilion’s interior to the park.
博物馆的入口由两个大型墙板构成,向上倾斜形成室内两层高的艺术展厅,形成其外观。 The entrance to Garage Gorky Park is marked by two large facade panels that slide upwards to frame the art in the lobby’s double height space and provide a view through the building from the park.
Location/地点
Situation/环境图
Site Plan/场地平面图
Level 1 Plan/首层平面图
Level 2 Plan/二层平面图
Mezzanine Level Plan/中层平面图
Basement Plan/地下室平面图
Section/剖面图
Section/剖面图
Hinged Panels/活动板
建筑设计:OMA 地点:俄罗斯 莫斯科 高尔基中央文化休闲公园 合伙人:Rem Koolhaas 项目设计师:Ekaterina Golovatyuk 面积:5400.0 平方米 年份:2015年 摄影师:Timur Shabaev, Yuri Palmin, David X Prutting 项目团队:Giacomo Cantoni, Nathan Friedman, Cristian Mare, John Paul Pacelli, Cecilia del Pozo, Timur Shabaev, Chris van Duijn 第二项目团队:Yashin Kemal, Timur Karimullin, Federico Pompignoli, Marek Chytil, Salome Nikuradze, Boris Tikvarski 当地设计师:Form Bureau (concept phase), Buromoscow (construction phase) 工程:Werner Sobek 景观设计:dUCKS, Les Éclaireurs |
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
四川浮生御度假村设计方案© Dirk Wieblen 在中国,泡温泉已是相传甚久的习俗了,它有助于健康和医疗保健。由AIM上海建筑事务所设计的浮生御度假村是一个反映当代社会建筑实践的杰出案例,尤其是作为为城市中产阶级设计的新设施。此度假村有着高质量的建筑和创新的空间布局,并为当今中国的地图上描绘了靓丽的一笔。温泉度假村坐落于四川省第二大城市绵阳以西50公里,那里是古代著名诗仙李白的出生地。项目所在地位于四川盆地的西北端,以喜马拉雅山脉为分界线。罗浮山在喜马拉雅山麓北侧的山脚下,矗立于周边相对平坦的地形。
全部回复(4 )
只看楼主 我来说两句-
sheji024
沙发
感谢楼主分享好资料
2016-07-07 15:23:07
轩辕圣子
板凳
俄罗斯莫斯科当代艺术车库博物馆,谢谢分享
2015-12-15 07:32:15
加载更多回复 举报
