土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 印尼Sharma Springs丛林度假别墅
发布于:2015-06-17 10:59:17 来自:建筑设计/居住建筑设计 [复制转发]
Indonesia Sharma Springs Jungle Holiday Home
设计方:IBUKU
位置:印度尼西亚 巴厘岛
摄影师:Rio Helmi, Errol Vaes
这是由IBUKU设计的Sharma Springs丛林度假别墅。这是为Sharma家族设计,作为丛林度假别墅。建筑共六层,四房,建筑面积为750平方米,能俯瞰Ayung河谷风景。该建筑几乎完全使用竹木建造,住宅入口时通过一个充满张力的隧道式桥梁直接引导人们进入四楼的露天客厅、饭厅以及厨房。中央塔楼的旋转楼梯通往低层的娱乐室、四间卧室以及图书馆,每个封闭的房间均设有空调和落地玻璃门窗。六楼的观景台可欣赏Ayung河谷与Green村庄的日落风景。建筑师还为这别墅专门设计了每一样家具和周边的花园。
From the architect. Sharma Springs was designed for the Sharma family as a jungle fantasy escape. It is a 6-level, 4-bedroom 750sqm home overlooking the Ayung river valley, built almost entirely of bamboo. The entry to the house is via a dramatic tunnel-bridge that brings you directly to the open-air living, dining, and kitchen spaces on the 4th level.
The staircases circle around the central tower to the levels below: a play room, as well as four bedrooms and a library that are each enclosed for air-conditioning with full length spinning glass windows and doors. The 6th-floor lookout is a front-row seat to the amazing sunset views over the Ayung river valley and Green Village.
Master metal smiths custom-built the shower stalls; stone carvers from Java carved boulders into counter slabs. Our team also custom-designed each item of furniture in this house. Ibuku, Gardens follows permaculture design principles, designed the surrounding gardens.
印尼Sharma Springs丛林度假别墅内部实景图
全部回复(3 )
居住建筑设计
28.74 万条内容 · 423 人订阅
【国外建房记】第六期 日本农村混凝土小住宅建造全过程
↑模型立体图1↑模型立体图2↑模型立体图3↑模型立体图4↑模型立体图5↑平面图↑剖面图↑敞开式厨房↑客厅,餐厅,厨房↑住宅地理位置↑施工场地测量放线↑供水↑地基勘探↑钢管桩运入↑机械钻桩↑钻桩顶端1↑钻桩顶端2↑
