土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 韩国首尔sangsang博物馆设计方案
韩国首尔sangsang博物馆设计方案
发布于:2015-06-16 11:58:16 来自:建筑设计/公共建筑设计 [复制转发]
Korea sangsang museum
设计方:moon hoon
位置:韩国 首尔
委托人:kang, young ho
摄影师:kim yong kwan
这是由moon hoon设计的sangsang博物馆。该项目包含有一处小型住宅、商业空间、办公区和一处知名摄影师工作室。项目位于首尔麻浦区,通过多种材质的运用表达出不同的使用功能。该项目包含一处从混凝土主体延伸出的木质屋面体块,和从背立面金属幕墙部分延伸出的开放钢结构,并在其之上形成了一处屋顶平台。
项目用地由三处地块构成,分散的用地形式决定了建筑的结构。需特别注意的是,建筑北立面临近一条20米宽的主干道,南面面向6米宽的小巷。因此在北向设计有通往商业区的入口,同时在南向设计了通往地下室和上层住宅的入口。这种布置将建筑两部分不同的功能分离,且避免了流线上的交叉,同时还保证了体块之间的联系。
两处独立的沿街立面为“sangsang博物馆”创造了两个风格迥异的立面形象。一处是木质装饰的立面,开设了规则分布的窗户和阳台,而另一处则保持了混凝土的外立面形象,设置了不规则的开口来作为建筑的室外平台。
the ‘sangsang museum’ unites a small residence, commercial space, offices, and a studio for a well known photographer client, while catering to his dracula alter-ego with a castle-like concrete shell. located in the mapo district of seoul, the project is one of the earlier realized buildings by korean architect moon hoon, and represents his ability to express disparate functional elements with diverse formal and material qualities. this includes a wood shingle-clad bedroom volume extending from the main mass, as well as a metal-skinned element on the back fa?ade that extends into an open steel frame shaping a rooftop terrace above.
the structure is shaped by a odd site that links three plots of land together. specifically, the building approaches a primary road (20 meters wide) at its north elevation as well as a perpendicularly-oriented alley (6 meters wide). the former provides a ground level entry to a commercial area while the latter allows for basement and upper level access to the residence. this arrangement functionally separates the two parts of the building to clarify circulation, while allowing for a continuity in its massing.
the two separate street-approaching elevations create two different faces for the ‘sangsang museum’. one is clad in wood and arranged by regular windows and small balconies, while the other maintains its concrete exterior with irregular breaks to accommodate outdoor patios.
公共建筑设计
51.18 万条内容 · 448 人订阅
瑞典乌普萨拉旅游中心设计方案
Sweden's uppsala tourist centerc 设计师:Skanska 设计方:Utopia Arkitekter 位置:瑞典 乌普萨拉 设计时间:2013年 项目规模:10600平方米 这是由斯德哥尔摩工作室Utopia Arkitekter设计的乌普萨拉旅游中心。这个“雕塑性的、引人注目的建筑宝石”方案赢得了这个市政建筑设计大赛。该项目低楼层布置了旅游中心、健身中心以及餐厅,而高楼层则布置办公室。该项目以LEED白金认证为目标进行设计,尊重自行车的使用,为乘客提供广泛的自行车停车设施,以及更衣室、沐浴设施等,以方便人们骑自行车过来训练。
