土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 波兰CRICOTAKA博物馆
波兰CRICOTAKA博物馆
发布于:2015-06-14 16:52:14 来自:建筑设计/公共建筑设计 [复制转发]
Poland CRICOTAKA Museum
设计方:Wizja Architects, nsMoonStudio
位置:波兰
建筑设计负责人:Stanis?aw Deńko (Wizja sp. z o.o.)、Agnieszka Szultk, Piotr Nawara (nsMoonStudio)
设计团队:Marcin Kowalewski, Artur Mizga?a, architects; ?ukasz Jakubowski, Micha? Marcinkowski, Daniela Skrzyp
合作人:IQ2-Group Consortium
摄影师:Wojciech Kryński , I?igo Bujedo Aguirre
这是由Wizja + nsMoonStudio设计Tadeusz Kantor的CRICOTAKA博物馆。该博物馆的空间设计通过影响室内、室外的边界,使空间变得更加的流动。通过特定的构件、结构、手法等,使创作者,艺术家,居民和游客共同参与空间的营造过程。这个也是博物馆的设计所要宣扬的信息。该博物馆并不作为一个静态的展示个人艺术作品的场所,而是作为艺术动态视觉的一个延续。博物馆营造出来的空间都似乎在大自然中真的产生的空间一样。根据Kantor的创造观点,博物馆不需要统一到周边的环境中,原有的建筑也不会通过其本质的功能来实现自身的识别性,相反是通过形式的对比与碰撞使他们存在于现今的环境中。
From the architect. Any time I manage to make something genuinely new, it is made of well-known elements of surrounding reality. It fascinates me as a kind of perversion, kind of unauthorized, unacceptable operation and I think it is the only way to find something truly isolated in art.
The Center of Documentation of the Art of Tadeusz Kantor “CRICOTEKA”, the symbol of artistic search for the individual path to creativity, crossing the border between the actor and the audience, between the creator and the and the recipient, engages everyone in an activity-game-collective play. The municipal public space constitutes both the stage and the audience; it is a venue for constant performance. Its value lies in effacing the borders between the inside and the outside, the space “flows”, it is shared. The creator, artist, residents and visitors all take part in the process, activity of creating space which can be shaped with selected objects, structures, means and methods. The Center of Kantor’s art should promote this message.
The building is not intended to function as a static presentation of the individual artistic works of the artist but rather as a continuation of his dynamic vision of art breaking away with conventions, valuing it not only for the autonomous character of form but also for the creative process which allows for the development of the artist and his work. The created space is a “preparation“ for action, which can take on a happening nature.
The Vistula river, its banks and directs surroundings are “objects and props” which can take part in the play and their presence on the stage (through a mirror reflection on the ceiling) provides grounds for creative use.According to Kantor’s creative visions, the museum building need not be integrated with the surroundings and the existing building does not fulfill its nature trough identification with is original function, but through a conscious contrast of form and content they create grounds for conflict and “clash”, thus marking their presence in the hitherto indifferent surroundings. The purpose of creative activity is not identifying the structure as a form but rather the way it interacts with the environs.
Abandoning the idea of developing the entire parcel ground and relieving it for purposes such as performances, exhibitions, shows, happenings in the Vistula riverside “theatre” extends the range of influence of the form and its content to the entire urban scale of the city.
Transforming the characteristic image of a man carrying a table on his back is a symbol of the “clash” between the matter, the object and a human being who-through his creative effort – invest a new form, endows the new “piece” with meaning and constitutes feedback originating from the combination of the idea of a creator and the choice of “material”.Particular zones of the new complex do not build a fixed order of functions, but rather create a semantic hierarchy for particular programmed elements.
Two forms visible from afar, adequately diverse in terms of functions, dominate the space, intrigue with the contradictions creating emotional tension and create the “field” of action in the centre of the complex. Expanded entry zones use space in the area and under it surface, introducing the participants-visitors to “action”, consisting in making choices, discovering the “material”.
The added building looks like a wrapped “object” with a “mysterious” and adequate to its function structure which is hidden behind the packing. The construction of the new part of the complex applies non-conventional solutions both in their material and static aspects (material: steel, reinforced concrete, glass) and the structure of buildings is resultant and derivative of the idea to form an external “theatre” space and create mutual tension between the individual elements of the entire arrangement.
Cricoteka building has a form of two intersecting arches made of spatial reinforced concrete steel truss based on two shafts. The third pillar is a steel, double-rocker. The branch support truss’s given implementing raise equal to their constant deflection under load and utility. Due to the complex geometry and other extensions, the raise values of the executive are different, which was included in the design of the cross. Rely on reinforced concrete prefabricated shafts was implemented through five pot bearings and one of the lens. Horizontal forces from the upper belt trusses are carried by special anchoring structures embedded in the shafts. The horizontal forces from the lower belts are passed in turn by the thrust on the walls of the shafts.
“Cricoteka” was established as a public utility institution and as such reserves the right to constitute a characteristic or even a dominant feature in the panorama of the city. The scale of the building – appropriately balanced – may reduce the negative influence of the surrounding tall buildings. The assumed height is similar to the height of the building in its background and much lower than the hotel recently built in the neighborhood.
波兰CRICOTAKA博物馆外部局部实景图
公共建筑设计
51.18 万条内容 · 448 人订阅
波兰华沙Sluzewski文化中心
Poland Sluzewski Culture Centre 设计方:WWAA + 307 Kilo Design 位置:波兰 华沙 合作人:Marcin Mostafa, Natalia Paszkowska, Jan Sukiennik, Maciej Kleszczewski, Wojciech Piwowarczyk, Anna Z 这是由WWAA + 307 Kilo Design设计的Sluzewski文化中心。该设计的最终形式是由两个因素决定:第一,现状以及城市文脉;,第二,设计自身的功能定义。现存的原文化中心以及其周边存在的生态环境、教育农场和乡村住宅也是设计灵感的源泉。整个项目包括两个相互关联同时又独立运作功能的建筑。入口广场通过圆剧场式的楼梯连接至1级的主要空间和建筑主要入口。这个地下盆似的空间可作为露天戏剧表演的舞台,同时可拆卸作为雨水收集器。建筑主要功能放置在地面下的1级,首层包括一个小型的开放公共空间和传统的房屋。每个房屋都作为独立功能空间,如一个艺术工作室或一个文学俱乐部。此外,设计将迷你动物农场引入中心,采用风能和太阳能来替代其他能源。通过改进传统农庄形式,该项目不仅深入了地方传统和文化,也显示了对城市与功能区边界的尊重。
