土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 加拿大温哥华岛地区图书馆
加拿大温哥华岛地区图书馆
发布于:2015-06-14 16:40:14 来自:建筑设计/公共建筑设计 [复制转发]
Canada Vancouver Island Regional Library
设计方:Low Hammond Rowe Architects
位置:加拿大
摄影师:Sama Jim Canzian
纳奈莫的北部分支图书馆项目位于纳奈莫的北部尽头,这个图书馆是为了满足大众的急切需要而修建的。项目工程包括对温哥华岛区域图书馆拥有和运营的原始中央服务大楼的现代化和翻修建设,温哥华岛区域图书馆找爱温哥华岛上一共有38个图书馆分支。原始建筑物位于哈蒙德海湾路北侧的一面上,这是一块天然的、树木繁茂的场址,树林中的树木主要是花旗松和松树,原始建筑物的两侧草木丛生,在原始建筑物东边有一个一层楼的消防站,原始建筑物的背面,即北部是一个原始的老年公寓综合设施。
项目的设计和翻修的灵感来源于围绕着场址的壮丽的树木。这样的设计和翻修也是为了与大自然的美连接在一起,并和在白天穿过松树林而来的阳光产生共鸣。我们的目的是通过将穿过树林而来的阳光引进建筑物的深处从而拥抱自然,并在分支图书馆的基础上就可以看见被保留下来的树木的风景。在建筑物内部,我们使用了大量花旗松制作而成的柱子和梁,还有坚固的花旗松甲板区支撑图书馆中基本的公共聚集空间,花旗松在不列颠哥伦比亚省是一种很多产的原料,花旗松的使用向游客们展示了珍贵的自然资源的力量和美。
The Nanaimo North Branch Library project serves to establish a much needed new branch library in the north end of Nanaimo and modernize & reinvigorate the existing Central Services building owned and operated by the Vancouver Island Regional Library, which services its 38 library branches across Vancouver Island. The building is situated on the north side of Hammond Bay Road on a naturally wooded site, defined by significant douglas fir and pine trees, and is flanked by a forested lot to the west, a one storey Fire Hall to the east and backs on to an existing Seniors Housing complex to the north.
Inspiration for the design and renovation of this building was derived from the majestic trees that surround and occupy the site; to connect with the natural beauty that resonates as the sunlight filters through the fir trees throughout the day. The aim was to embrace our connection to nature by capturing the filtered daylight deep into the heart of the build- ing and allow views, from base to limb, of the very trees being preserved. Internally, the building incorporates substantial douglas fir glue-lam columns & beams and solid fir decking, harvested and produced in BC, to support the primary public gathering spaces in the library, signifying to the visitor the strength and beauty of this valued natural resource.
公共建筑设计
51.18 万条内容 · 448 人订阅
内蒙古鄂尔多斯博物馆设计方案
Inner Mongolia Ordos Museum 设计方:MAD建筑事务所 位置:内蒙古 鄂尔多斯 MAD设计的鄂尔多斯博物馆近日落成,它好像是空降在沙丘上的巨大时光洞窟,其内部充满自然的光线,正将城市废墟转化为充满诗意的公共文化空间。六年前还是一片戈壁荒野的内蒙古鄂尔多斯新城今天充满争议,而争议本身已经将其置于更广泛的中国当代城市文化反思的焦点,它让公众重新理解地方传统和城市梦想的关联和矛盾,同时,也迫使我们理解那些被边缘化的地方文化所爆发出的对未来深切的渴望。2005年,在一片荒野上建立一个新城区的城市规划图制订后, MAD受到鄂尔多斯市政府的委托,为当时尚未成形的新城设计一座博物馆。
