土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 奥地利Weritas品酒中心
奥地利Weritas品酒中心
发布于:2015-06-14 17:42:14 来自:建筑设计/公共建筑设计 [复制转发]
Austria Weritas Wine Tastes Central
设计方:gerner°gerner plus
位置:奥地利
设计团队:Matthias Raiger, Peter Blasl, Laurenz Vogel, Oliver Gerner, Christian Münster
摄影师:Matthias Raiger
这个新的品酒中心位于下奥地利州,瓦格拉姆的基希贝格,占地面积大约550平方米,是一栋两层楼的建筑物。建筑物的主结构由钢筋混凝土和玻璃墙后附加的钢柱组成。因为建筑物中有一个面积很大的地下空间,所以建筑物看起来比实际大小要小。可见的建筑部分拥有绿-灰色的纤维水泥墙壁,它坐落在一个急坡上,随后的地形模型将建筑物平稳的融入了周围的环境当中。只有一个位于树木中间并明显可见的玻璃体量被当做了一个地标。
建筑物的场址是一个陡坡的情况实际上被证明了是一个技术优势。因为这样,建筑物的地下空间在炎炎夏日还可以保持凉爽,从而减少了对空调的使用。通过使用地热能,建筑物达到了低能耗的标准。整个建筑物都被设计成了无障碍且易接近的形式。品酒间位于建筑物的一楼,作坊和仓库则位于建筑物的地下室中,通过一些坡道就可以进入地下室,在建筑物的每一个楼层中都有为残疾人准备的公共洗手间。
The new regional visitor and wine center in Kirchberg am Wagram, Lower Austria, comprises about 550 square metres floor space on two levels.The main structure of the building is made of reinforced concrete with additional steel columns behind the glass facade. A large underground space makes the building appear smaller than it actually is. The visible building part with its green-grey fibre-cement facade sits on top of the steep sloping site and the subsequent modelling of the topography blends the building smoothly into the surrounding landscape. Only a glass-box stands out considerably between the trees and is clearly visible as a landmark.
The location of the building on a steep slope has actually proved to be a technical advantage. The underground spaces stay cool in summer and reduce the need for air conditioning. By using geothermal energy the whole building reaches low energy standard.The complete building is designed to be barrier-free accessible. The tasting room in the first level as well as the workshop and storage rooms in the basement can be reached by ramps and restrooms for handicapped persons are provided on both floors.
  • yuyanhui63
    yuyanhui63 沙发
    很好的资料啊,谢谢楼主!
    2016-07-07 05:48:07
  • cmlhjcfs
    cmlhjcfs 板凳
    挺有味道的建筑,见识了,谢谢分享。
    2016-07-06 22:09:06
公共建筑设计
51.18 万条内容 · 448 人订阅
新西兰国库研究中心和档案馆
New Zealand Treasury Research Centre & Archive 设计方:Architectus 位置:新西兰 项目规模:200平方米 摄影师:Simon Devitt 修建这个项目的意图是修复和继承历史上有名的Thames Carnegie图书馆,并为Thames Coromandel区域提供存放档案和系谱的设施。将一个记录在案的遗产结构修复并改造成一个存放档案和系谱的中心为我们提供了一个独特的设计挑战。关于档案存储和管理等方面专业化的要求将对原始建筑物的遗产结构产生威胁,所以我们在原始遗产结构上进行了扩建。虽然在20世纪早期的时候就为城镇修建了图书馆设施,但图书馆还是需要经过仔细的转换去满足项目对接待、研究、存储和行政管理上的要求。
