土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 俄罗斯微软科技馆设计方案
俄罗斯微软科技馆设计方案
发布于:2015-06-14 16:38:14 来自:建筑设计/公共建筑设计 [复制转发]
Russia Microsoft science museum
设计方:Nowadays
位置:俄罗斯
设计团队:Anna Ivyanskaya, Natalya Mastalerzh, Nata Tatunashvili
摄影师:Ilya Ivanov
这是由Nowadays设计的微软科技馆,该项目为2014年索契冬季奥运会而设计。每个奥运会赞助商都在奥林匹克公园得到一块25×30米的标准矩形地块。客户期望能创建一个公共空间,让游客在比赛间隙在这里会面交谈。因此建筑师一改建筑单体布置在场地中央的布局形式,采取了将所有功能分布在场地周边的方式,使得建筑创造了多层次的庭院空间,容纳多种活动。展馆为木结构形式,坐落在同一个平台上。Windows8操作系统界面的色块转化为地面上正方形的彩色铺装,同时划分空间。建筑立面表皮和围墙使用了木条。
From the architect. The Microsoft Technology Pavilion was designed by architectural firmNowadays for the 2014 Winter Olympic games, held in Sochi. Standard rectangular plots 25×30 meters were given to sponsors of the Games in the Olympic park.
One of the main requirements of the Olympic Committee was to locate a single volume on the site. But the clients wanted to create a public space where visitors could meet between competitions. So architects decided to rethink the proposed layout of a single building in the center of the site and distributed all the functions around the perimeter. It gave the opportunity to create a multilevel courtyard, saturated with various activities.
The pavilion was built of wooden structures on a single platform. The color palette of the windows 8 interface was transferred to the floor in the form of squares of colored chips, literally zoning space. Facades and fences are made of wooden slats that unite all the volumes on the platform in the whole complex, still maintaining airiness and layering.
It’s achieved by complex coloring of inner cubes and external facades – each slat has only side faces painted and in different colors, so that while in motion the moire effect appears. The boundary between interior and exterior space is blurred, for example the amphitheater passes through the wall, organizing lecture room inside and a large sitting area outside.
俄罗斯微软科技馆外部细节实景图
全部回复(3 )
  • yuyanhui63
    yuyanhui63 沙发
    很好的资料啊,谢谢楼主!
    2016-07-07 05:47:07
  • cmlhjcfs
    cmlhjcfs 板凳
    花花绿绿,就像一个休闲场所,非常有利于工作。
    2016-07-06 22:12:06
公共建筑设计
51.18 万条内容 · 448 人订阅
丹麦莫西加德博物馆设计方案
Denmark Moesgaard Museum 设计方:Henning Larsen Architects 位置:丹麦 新莫西加德博物馆的位置很独特,它坐落在拥有起伏地形的斯卡娣。博物馆的屋顶是倾斜的,上面长满了草、苔藓和颜色鲜艳的野花。博物馆的建筑物在视觉上是非常显眼的标志性建筑物,就算在海上都可以看见博物馆。博物馆矩形的屋顶就像是从地底下长出来的一样,在炎热的夏天,这个屋顶将会为野餐、烧烤、户外演讲和传统约翰节施洗篝火提供区域。在冬天降雪时,倾斜屋顶将会变成城市中最好的滑雪场。
