土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 埃及亚历山大图书馆设计方案
埃及亚历山大图书馆设计方案
发布于:2015-06-14 16:46:14 来自:建筑设计/公共建筑设计 [复制转发]
Egypt Bibliotheca Alexandrina
设计方:斯诺赫塔建筑事务所
位置:埃及
摄影师:Bibliotheca Alexandrina
这是由挪威工作室Sn?hetta设计的亚历山大图书馆,是埃及地中海沿岸一个壮观而先进的设施。现状建筑制图作为该城市历史与遗产的联系,并以鲜明的现代性和技术创新,使其更具前瞻性,该项目是建筑形式与工程的一种探索,寻求一种更强的区域归属感。虽然该项目需要考虑到政治、社会和历史的语境问题,Sn?hetta设计的这个当代图书馆值得作为一个独立案例进行研究和评价。该建筑共11层,提供图书馆设施、文化和教育功能设施,如天文馆、若干博物馆、一所信息科学学校和一些历史保护设施。建筑形式为圆形、倾斜的形式,其跨度直径160米,最高高度达32米,同时嵌入地面12米。建筑被开放的广场和倒影水池所包围,一座人行天桥将其与城市及周边亚历山大大学相连。该建筑的设计经典而又大胆,成为这座城市学习和文化的新标识。
The Bibliotheca Alexandrina on Egypt’s Mediterranean Coast is a spectacular, state-of-the-art facility with an unresolved architectural identity. Commissioned in 1989 as a contemporary resurrection of the fabled Library at Alexandria once venerated throughout the ancient world, the present building was intended to serve as a city’s connection to history and heritage. But its stark modernity and technological innovations make it decidedly more forward-looking than historically referential, a cosmopolitan exploration of form and engineering perhaps longing for a stronger sense of regional belonging.
To some critics, the library has political overtones that obfuscate its architectural message, at worst acting as a monument to political posturing whose utility and conceptual integrity is only of secondary concern. And while critical scrutiny of the project necessitates its political and socio-historical contextualization, the building’s architecture—the competition-winning design submitted by Norwegian firm Sn?hetta—is worth appreciating and evaluating as an autonomous object and as a precedent for contemporary library design.
From the shoreline, the library appears as a disc-shaped volume one hundred-sixty meters in diameter, tilted forward toward the water in the shape of a wedge. The architects intended the pure geometry of the circular plan to “recall the cyclical nature of knowledge, fluid throughout time” and to reflect the circular layout of the Alexandrian harbor. [1] Although this blithe description is fairly specious taken literally, the reference suggests a genuine appeal to a timeless, universal, and perhaps archetypal form, both evocative and provocative in its purity. And in this it succeeds; between its massive size and its striking, clean profile, the Library exerts a commanding, primeval presence over the harbor city.
The difference between aerial photographs and the in-vivo experience is essential to the comprehensibility of the library: what may appear from images and models to be a monolithic, blocky diagram is far from the in-person impression afforded from the ground plane. Complexity is contributed at the human scale through structural and material details, incisions into the circular shape, and an elaborate interior program contoured to the dramatic incline of the roof. The interplay of multi-directional curves and intersecting planes gives the library an energetic dynamism, particularly from the exterior approach. In an age in which buildings are too often intended to express themselves best through renderings, the Bibliotheca provides Alexandria with welcome relief: a library designed for consumption through physical occupation rather than through simulacra (although the possibility exists that this is a merely generous reading of a building whose concept is simply clumsy in any other medium).
The carefully choreographed groundscape constitutes one of the great successes of Sn?hetta’s design. Around the exterior, an expansive open plaza and a reflecting pool buffer the library from the chaotic environment of urban Alexandria and provide it with a dramatic and forgiving canvas from which its unusual form can emerge. Dipping below the water table created by the pool, the entire library volume seems to pivot atop the surface of the Earth, an effect emphasized by the angled gradient of the granite-clad walls. On the southern side, this monolithic, curved profile dramatically soars thirty-two meters above the plaza without revealing anything of the building’s overall form to the city behind it. As an homage to history and tradition, this wall is carved with a series of texts in languages both modern and extinct, alluding to the library’s worldliness. Although these token bits of symbolism are visually entertaining and beautifully executed, they ring somewhat hollow, as if the difficulty of genuine cultural evocation on a more fundamental or conceptual level gave way to a literalist and superficial attempt to convey the library’s function.
Inside, just below the sloping crystalline canopy, the great reading room—the crown jewel of the library—brings the size and magnificence of the design into a single view. Seven stacked tiers of platforms, reminiscent of the trays of Harvard’s Gund Hall, overlap one another in an unending expanse of diagonally vectored space, large enough to house some two thousand visitors. Soaring columns lift the ceiling high into the air, recalling the dramatic, flaring supports of Labrouste’s Bibliotheque Nacionale and Wright’s Johnson Wax Building. Perhaps in this spectacular arena alone, the building is truly recognizable as a library, functionally and genealogically tied to a typological model well established in architectural tradition.
It is in this reading room, too, that the architecture most glorifies the acts of scholarship and erudition. Basking in diffuse northern sunlight pouring through the roof, the warmth of the natural wood finishes and the staggered floor arrangement create thrilling Bachelardian moments of space that straddle the diametrics of the intimate and the immense. Richly textured wall finishes, meticulous structural articulations, and an innovative skylight system with the sculptural playfulness of a Miralles window sequence break down the enormous space further into a delicate interplay of details on an appreciably human scale.
Book and manuscript repositories, capable of housing over eight million volumes, neatly occupy the spaces below the reading room. Other elements of the interior program, including permanent exhibits on Egyptian politics past and present, art galleries, a planetarium, and a school for information sciences complete a well-choreographed and impressive presentation to visitors. The library’s eleven floors, with an overall height of forty-three meters, create an astounding 80,000 square meters of floor space—one of the largest libraries in Africa by area.
Of course, the standard metric of library size used elsewhere—collection capacity—reveals problems with the politics of the Bibliotheca’s origins. The final construction price tag of nearly $200 million left little funding for the library’s collections, and despite a sizable gift of a half-million Francophone books from the French government in 2010, the building will operate severely under capacity for the foreseeable future. [2] The lack of post-construction consideration presents a conflicting narrative of the building as the vanity project of an unpopular government, a vehicle of international posturing and a domestic display of false prosperity undertaken with disregard for real utility. And of course, this possibility raises concerns about the fiscal responsibility of a massive, luxurious civic project in a country with troublingly high rates of poverty and food insecurity (among other more recent crises), though the larger question of the merits of architectural and infrastructural investment are subject to another, larger debate.
The more immediate questions posed by the library engage architectural theory with questions of intentionality. As concerns the architects, should their inspirations and spoken testimony affect our reading of the finished product? Should the agendas of the government that financed the project alter our understanding of its success? Or can the library’s architecture be appreciated independently and autonomously, studied for its innovations and wonders, and absolved of accountability for erroneous decisions of process and priority? Such a reading would act to the benefit of this particular project, whose architectural merits deserve commendation but stand to be overshadowed by placing it within the context of a political game.
  • zf19861015
    zf19861015 沙发
    这个图书馆真大啊
    2016-03-28 22:41:28
公共建筑设计
51.18 万条内容 · 448 人订阅
法国赛特市海事博物馆设计方案
France Sater Municipality Maritime Museum 设计方:C+D Architecture 位置:法国 塞特市 建筑设计负责人:Nicolas Crégut, Laurent Duport 工程师:Grontmij 摄影师:Marie-Caroline LUCAT 这是由C+D Architecture设计的赛特市海事博物馆。建筑前身是法国海洋开发研究所(法国科研机构,海洋开采方面),被弃置了十年之久,如今建筑师对其进行重建和维护,展出许多宝贵遗产和历史文物,述说这个港口城市的悠久历史。博物馆首层设置了三个展区。面朝大海一侧设置了横向长窗,将广阔的海景尽收眼底。建筑师尽量保留了原有建筑的结构特点,将重点放在扩大馆内空间和布局结构改造上,同时对墙壁和天花板进行了修复和维护。
