土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 奥地利Vorarlberg博物馆
奥地利Vorarlberg博物馆
发布于:2015-06-14 15:40:14 来自:建筑设计/公共建筑设计 [复制转发]
Austria Vorarlberg Museum
设计方:Cukrowicz Nachbaur Architekte
位置:奥地利
设计团队:Anton Nachbaur-Sturm, Andreas Cukrowicz, Stefan Abbrederis [PL], Martin Ladinger, Philipp Schertler
摄影师:Hanspeter Schiess , Adolf Bereuter, Darko Todorovic
这是由Cukrowicz Nachbaur Architekte设计的Vorarlberg博物馆,位于康斯坦斯湖边。该项目基于建筑连续性的设计原则,对建筑进行了水平方向和垂直方向上的扩展,通过对比、联系等手法创建了一种新的建筑形式。博物馆的选址能欣赏开放的康斯坦斯湖风景以及布雷根茨紧凑布局的城市肌理。建筑的布局以及建筑之间的空隙创建了一系列不同的个性鲜明的外部空间,视线良好。作为整体,还可被解读为公共广场的线性序列空间。该博物馆回应了场地条件,大幅度地保留并融入了新的建筑。所有材料的使用都符合可持续生态的选择标准。整个建筑的墙壁和天花板使用了粘土,使得建筑的通风设备安装减少了三分之一,照明系统运用了LED技术。
From the architect. The new Vorarlberg museum completes the row of several culture buildings at the waterside of Lake Constance. The extraordinary concept is based on the principle of architectural continuity and it expands a listed building vertically and horizontally generating a new building form not by contrast but by contact of all parts differentiating them only by their surface structure.
The Museum occupies a site at the transition from the open landscape of Lake Constance to the compact urban structure of central Bregenz. At the edge of the otherwise impermeable urban fabric stands an insular row of detached landmark buildings. Their placement, as well as the gaps between them, creates a spectrum of different exterior spaces with unique character open to views of Lake Constance. As a whole, the quarter can be read as a continuous sequence of public squares.
The Museum responds to the local conditions completing the row of stand-alone landmarks. An assertive urban and architectural intervention provides the ideal vehicle for restoring the Vorarlberg Museum’s stature alongside the Kunsthaus and theatre in Bregenz’s culture quarter. The concept of the Vorarlberg Museum is based on the principle of architectural continuity. The listed building, which originally housed the District Council, was substantially preserved and assimilated into the new architecture.
The original building was expanded upwards by two storeys, in addition to the five storey extension onto Kornmarkplatz. These three different components are unified in a clear and compact new form. The different stages of the Museum’s history are rendered visible through varying facade composition and surface textures, but a singular colour palette of chalky white and champagne tones unites all components into a discrete whole. This colouring breathes new life into the facades, warmly diffusing natural light into the surroundings. The Museum’s combination of newfound height and colouring exerts a strong presence across the urban context and Lake Constance.
All functions are arranged around a central atrium, with a ring of circulation connecting each internal area. The open and inviting ground floor, containing the foyer and café, joins the inner court to the public space outside. The first floor holds two function rooms, which can also be used as flexible exhibition spaces. The Museum’s entire administration team is accommodated on the first floor of the building. The top three floors are specialised exhibition spaces which prioritise flexibility of use. Varying views to the atrium and outside provide subtle differences in the spatial experience, without compromising the spaces’ flexibility.The area in front of the panoramic window on the fourth floor can serve as a contemplative or relaxing space. The atrium provides generosity of space and a means of orientation within the building, and is furthermore a versatile space well suited to hosting installations and events.
The re-use of an historic building and giving it a second life is a very important aspect of sustainability. All materials and themes are derived from the historic substance and were transferred into a new language. Every exterior building part is made in passive house quality.The use of all materials is sustainably untreated and chosen after ecologic criteria. By using clay as an material for walls and ceilings in the entire building the installations for ventilation could be reduced to a third. LED-technology is used for the whole lighting system.
全部回复(10 )
  • yuyanhui63
    yuyanhui63 沙发
    有创意,真不错的
    2016-01-25 17:25:25
  • wanshuns
    wanshuns 板凳
    谢谢楼主分享好资料
    2016-01-25 10:31:25
公共建筑设计
51.18 万条内容 · 448 人订阅
法国里昂汇流博物馆设计方案
The convergence of Lyon, France museum 设计方:Coop Himmelb(l)au 位置:法国 摄影师:Duccio Malagamba 这是由Coop Himmelb(l)au设计的法国里昂汇流博物馆。它是重振里昂的主要项目工程。建筑位于该地区两条主要河流的汇流处,地理位置更加强化了 博物馆 对比与发散的主题,即融合不同的独立实体形成一个新的动态结构。在结合了科技、生物学、伦理的宏大主题下,该项目不仅是一座博物馆 ,也是一处与城市休闲功能融为一体的积极活跃的公共集会空间。
