土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 丹麦罗斯基勒青少年中心
丹麦罗斯基勒青少年中心
发布于:2015-06-14 15:03:14 来自:建筑设计/公共建筑设计 [复制转发]
Youth Centre
设计方:Cornelius + Vöge
位置:丹麦 罗斯基勒
竣工:2012年
摄影师:Adam Mørk
建筑面积: 600 平方米
这是一个原有建筑的改扩建项目,位于历史久远的小村庄与七十年代的住宅区之间,为了强调地域特色,建筑外观选用了当地谷仓与渔民小屋传统中采用的红色,这是当地村庄建筑最为显著的特点。屋顶与外墙设计成成同样的颜色,使得整个建筑简练精确,更突出了它的基本形态。建筑被改造成低能耗的环保建筑,设计师利用新型的维护材料,将其改造成为更开放、更现代、更有趣味的建筑形态并新增加了一些空间,阳台和楼梯结合在一起,更多的私密交流的角落,室内室外的活动区等。周围的绿地也更加完整,阳光充沛。扩建部分包括一个多用途的音乐厅,剧场,体育馆,和一面攀岩墙壁。建筑外立面上的一些设计元素消解了整个建筑的基本体量,减小了建筑的尺度感,比如可同时作为小舞台的楼梯、入口雨棚和转角飘窗。这个角窗悬挑出外墙面,形成了介于室内外之间的空间,为孩子们提供了一个可用于小团体聚会玩耍的私密角落。
The project is a conversion and extension of an existing building.The building is located between an old village and a seventies development, so in order to underline a regional identity to the building it was coloured all red. The red colour follows the tradition of the old fishermen cabins of the village, which are one of the most characteristic elements of the village. The roof has the same colour as the facades to make the shape of the building more precise and simple underlining the basic shape of the building.The building is renovated into a low energy building, covered with new facade materials and reorganized into a more open, playful and modern building. New covered areas, balconies and stairs integrates more intimate corners and living areas both outside and inside. The surrounding green areas are more integrated and daylight optimised. The extension includes a flexible multi purpose hall for concerts, theatre, playing and sports activities including an integrated climbing wall.Several fa?ade elements breaks the basic shape of the building into a smaller scale: a stair functions as a small stage area, covered entrances and the corner window which cantilevers from the building and creates a more intimate living space for the children to sit in smaller groups – a private space being a part of the interior and exterior at the same time.
青少年中心-14
全部回复(4 )
  • 点思设计
    点思设计 沙发
    好设计!赞!
    2015-12-19 11:12:19
  • 石大侠
    石大侠 板凳
    很有意思的设计!
    2015-06-14 17:39:14
公共建筑设计
51.18 万条内容 · 448 人订阅
北京万科赢家俱乐部设计方案
Yingjia Club at Vanke Beijing 设计方:Neri & Hu Design and Research Office 位置: 北京 竣工:2012年 摄影师:Shen Zhonghai Neri&Hu设计事务所最近完成了中国万科集团的一个项目,位于北京万科总部。这座赢家俱乐部是一座新的五层多功能VIP销售俱乐部,建在业主现有的办公区内。这对万科来说是一个里程碑式的项目,是近几年中开始支持世界级的设计师和环保建筑的结果。反映在设计任务书中要求建筑具有突出的外部特征,室内空间则需要再长时间内能够适应灵活多变的功能。Neri&Hu设计了一种创新的立面形式,其内部空间的体验由不同层次的许多公共空间和私密空间串联而成,通过连续的旋转楼梯相互联系。建筑从北京传统的四合院住宅中提取灵感,私人空间与公共空间的关系层次不仅是垂直方向上的,也体现在水平方向。那些道路和透景吸引人们去探索所有的空间。室外一单一的遮阳板将复杂多变的室内空间遮挡起来,形成一个简单的遮阳板方盒子,统一了不同的窗口。随着对建筑空间的不断深入,空间由于对材料色彩的应用和光线品质的变化,变得更明亮,颜色更轻,空间更开敞。黑色向隧道一样的入口唤起了神秘感和排它性,暗示着接下来的旅程也将在阴影中走过。狭长的主入口过去之后就到了3层的接待厅,不同层次的感受都在这里展开,压抑和开阔、公共和私密、明与暗、天空和土地,这些经验将随着来访者的步伐逐步展开。沿着洞穴般的安静走廊前行,会从洞口瞥见两个主要的双层通高的空间:接待厅和展廊。通过这些巨大的中庭空间、重叠的框景墙洞以及天窗,可以让风景穿透不同层次的各个房间,通过视线联系加强了访客对空间的好奇。
