土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 西班牙马德里红牛音乐学会
西班牙马德里红牛音乐学会
发布于:2015-06-14 14:23:14 来自:建筑设计/公共建筑设计 [复制转发]
red bull music academy
设计方:langarita-navarro arquitectos
位置:西班牙 马德里
竣工:2011年
摄影师:luis diaz diaz
原定于设立在东京的红牛音乐学会还球音乐节由于2011年那场大地震不得不紧急将举办地改在了西班牙马德里。只有5个月的时间来设计新的举办场地,当地设计公司langarita-navarro arquitectos在两个月内创造出一系列空间,尽量减少了对原场地的影响,并使其实现了标准化和高度的适应性。场地原来是一些旧仓库区,后来慢慢变成了各种活动的举办空间。设计包括办公室、音乐家工作室、录音棚和用于会议、无线广播和休息室的多功能厅,这些功能都位于一个面积达4700平方米的开阔场地。该项目全部由临时构筑物组成,保持了原来库房中钢构架和砖墙立面的完整。将来可以完全不留痕迹的回收所有这些构筑物,并将其再利用到其他场所。解决方法是把原来的结构当做天蓬,覆盖着下方的微型城市,就像俄罗斯套娃一样将那些构筑物完美的结合到大空间之下。那些独立的活动小屋由便宜的胶合板材料制成,内部采用轻质铝构件作为龙骨,底层放置在金属搁架上。定向刨花板铺成的地板将这些各自独立的单元组织在一起。每个小木屋都有其独特的功能,在声学上有特殊要求,隔声是通过堆叠起来的沙袋和屋顶多彩的帆布天花板实现的。这个充满阳光的仓库就像是一座公园,培育着艺术之花,并可以移栽到其他任何地方。灵活的设计使这里将来可以作为多种用途或者简单的全部撤走。
set to be held in tokyo, the 'red bull music academy' traveling festival was urgently relocated to madrid due to the devastating effects of the earthquake in 2011. with only five months time to design a new venue, local firm langarita-navarro arquitectos created a sequence of spaces that were constructed in two months, intruded minimally on the existing site and illustrated the ideas of standardization and adaptability. located in the group of historical warehouses that make up the 'matadero,' slowly being repurposed into various creative spaces (see designboom's coverage of the 'reader's house'), the design contains offices, musicians' studios, recording studios and a flexible area used for conferences, radio broadcasts and lounge in an expansive open space of 4,700 m2. the project is made up of entirely temporary constructions, leaving the original steel structure and brick facade building intact, with the ability to recycle all components of the intervention into new systems without leaving a single trace on site.the solution is to use the aging structure as a canopy over an urban microcosm, comparable to the concept of a matryoshka doll whereby a component is perfectly incorporated into the other in a permanent or temporary fashion. smaller independent moveable houses made of affordable plywood panels on a lightweight aluminum frame skeleton sit off of the ground on truss foundations, while an oriented strand board (OSB) deck unites the individual units into a sort of homogenous community. each timber 'dwelling' is designed for its specific function, paying special attention to acoustic requirements, while soundproofing is achieved through a wall of stacked sandbags and colorful canvas ceilings help control sound reverberation. the smaller constructs exist within an 'exterior' environment, where the light filled industrial building is turned into a park with various cultures of potted plants that can later be replanted in diverse locations. the flexibility of the design allows for a variety of future uses or a removal of all pieces altogether.
红牛音乐学会-13
全部回复(3 )
  • 加倍努力
    加倍努力 沙发
    多谢楼主!很有创意的建筑。
    2016-07-05 08:58:05
  • yuyanhui63
    yuyanhui63 板凳
    挺好,谢谢分享。
    2016-07-05 05:35:05
公共建筑设计
51.18 万条内容 · 448 人订阅
瑞士洛迦诺电影院设计方案
设计方:MAURO TURIN ARCHITECTES 位置:瑞士 该项目是由MAURO TURIN ARCHITECTES设计,位于瑞士洛迦诺,成为城市景观的一个亮点。 瑞士洛迦诺电影院-2瑞士洛迦诺电影院-3瑞士洛迦诺电影院-4瑞士洛迦诺电影院-5瑞士洛迦诺电影院-6瑞士洛迦诺电影院-7瑞士洛迦诺电影院-8瑞士洛迦诺电影院-9
