© Federico Cairoli
本项目位于“colastiné”郊区一个20mx 50m的地块,构造方面定义了两点,首先将砖作为参考材料,其次,使用金属屋面。 From the architect. This project is located in a suburban lot 20 x 50 meters in the neighborhood of “Colastiné”, tectonically defined by two aspects, firstly the use of brick as a reference material, and secondly, the metal gable roofs.
© Federico Cairoli
© Federico Cairoli
轻便的“金属毯”,独立于墙体,在入口、餐厅、起居室和多功能烧烤区等一系列建筑项目中界定出社交空间,主视点结束在游泳池和公园。玻璃建立起室内外空间的连接,并随之模糊了“内”与“外”之间的边界。 The weightless “metal blanket”, independent of the walls, defines the social space of the architectural program in a succession of entry, kitchen, living-dining room and multipurpose barbecue area, that end on the main views of the pool and park. Glass envelopes interconnect between the indoor and outdoor spaces, allowing for this dialectic that blurs the boundaries between “inside” and “outside”.
Plan/平面图
© Federico Cairoli
© Federico Cairoli
在这个社会性的项目下,我们设计了包含私人区域的体块,我们使用一个不太透明的材料,可以在保证照明和通风的条件下,产生更多隐私区域,并考虑了空间气候情况。 Juxtaposed on this social program, we lay out the volume containing the private area, where we worked with a less permeable enclosure, in order to generate more privacy without losing the necessary lighting and ventilation, contemplating the bioclimatic situation of such spaces.
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
© Federico Cairoli
Elevation/立面图
Elevation/立面图
Elevation/立面图
Elevation/立面图
Section/剖面图
© Federico Cairoli
建筑设计:Estudio Puyol – Meinardy 项目位置:阿根廷,圣达菲colastine 项目建筑师:Gervasio Meinardy, Ma. Dolores Puyol, Virginia Fabre, Leticia Santarelli, Milagros Reinante 合作伙伴:丽萨罗斯 项目面积:224平方米 项目时间:2014年 摄影: Federico Cairoli |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
罗马尼亚布加勒斯特Dogarilor公寓大楼© Cosmin Dragomir 时至今日,布加勒斯特最大最严峻的城市问题是市中心人口密度过大。虽然我们相信密度很多时候被视为可持续发展的一种形式。同样,在一个老旧社区中脆弱的邻里关系以及人口密度的加大往往改变一个地区,并降低其现有的生活质量。From the architect. One of the most important and problematic aspects of nowadays Bucharest is the fast densification of the central area. While we believe that density can, and many times must be seen as a form of sustainability, we also admit that the often fragile relationship between habitation within an old neighborhood and the increase of density could many times alter the place and reduce its existing qualities.
全部回复(3 )
只看楼主 我来说两句-
flh20077
沙发
2015-07-08 08:42:08
ymwatcher
板凳
见识了,谢谢楼主分享。。。
2015-07-07 17:58:07
加载更多大奉献啊,给力
