土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 法国Radiant文化中心设计方案
法国Radiant文化中心设计方案
发布于:2015-06-13 20:53:13 来自:建筑设计/公共建筑设计 [复制转发]
France Radiant cultural center
设计方:Z Architecture
位置:法国
摄影师:Jonathan Letoublon
这是由Z Architecture改造的Radiant文化中心。经过20多年的使用,Radiant Bellevue文化中心需要重新的修缮以适应现代的标准和实际使用需求。除了建筑本身的修缮以外,该项目也是提供了一次将建筑和周边居民、环境再次取得联系的机会。该项目中,设计团队决定为文化中心设计了一个新的入口,将入口设计在建筑的正面,从而营造一个游憩的空间。为了避免阳光照射到首层,设计团队在建筑中增加了垂直的铝制的遮挡板,从而减少热量进入建筑内部,此外,建筑的大堂增加了酒吧和接待处等设施,沿着大堂的曲线达到观景台,这里可以饱览周边的美景。新的音乐厅新增一个移动看台系统,有700多个座位或2500多个站位。
From the architect. After more than 20 years of use, the Radiant Bellevue had to be rehabilitated to adapt to current standards and practices (change bleachers, setting accessibility, replacing the sound system, renovating the reception area and refurbishment of the facades) .
Beyond simply responding to the program, the project was an opportunity to reconnect the Caluirards and more widely the inhabitants of Rh?ne-Alpes with the wonderful scenery of the Balmes of Caluire (small hills in the Rh?ne-Alps region). In this purpose, most planned developments have been designed toward the new relationship that the cultural center will have with his “Grand Landscape of the Monts d’Or.”
The historic entrance of the Radiant-Bellevue was on the back-side of the building, turning his back to the landscape but facing the principal street of Caluire-et-Cuire. The architectural team decided to move up front this entrance, creating a new esplanade which will take advantage of the unique point of view on the surrounding landscape and will connect to the architecture of the town hall.
In order to protect the hall form the sunlight, the architect added vertical, bicolor shades made of aluminium that would lessen the thermic impact on the glass facade while style offering transparency. The old entrance is transformed into a signaletic facade made of steel blades.This new acces leads to a new lobby that includes a bar and a reception made of the same wood and steel. The ceiling is punctuated with lights that create a homogeneous atmosphere at night and bring a magic lantern effect from the outside of the concert hall. The curved shape of the lobby is followed by the glass facade that opens the view on the balmes.
Following the curve of the lobby, the creation of a terrace offers a unique point of view on the landscape surrounding the Radiant-Bellevue. Made out of a steel structure and a wooden floor (massive larch), this new outdoor space adds a unique perspective for the artists and the spectators.The concert hall introduces a new moving bleachers system that can accept up to 700 seated person or 2500 standing person when retracted. The hall is also rehabilitated to the current standards of accoustic and scenography.
法国Radiant文化中心剖面图
全部回复(4 )
  • 紫花果
    紫花果 沙发
    好有创意,好看
    2016-04-11 16:57:11
  • 石大侠
    石大侠 板凳
    好设计!赞!
    2016-03-29 10:06:29
公共建筑设计
51.18 万条内容 · 448 人订阅
法国圣日耳曼文化中心设计方案
France Cultural Center 设计方:Ateliers O-S architectes 位置:法国 圣日耳曼 项目预算:5934000欧元 摄影师:Courtesy of Ateliers O-S architectes 在2010年,圣日耳曼阿尔帕荣镇就开始想要修建一栋新的设施,设施中包括一个电子图书馆和一个音乐、舞蹈学校。这个文化中心完工后将会取代当前的音乐、舞蹈学校和当前的公共图书馆,当前的公共图书馆坐落在一个小的、功能有些故障的建筑物中。修建文化馆的场址是这个城市选的,场址呈长而狭窄的带状,这个场址坐落在一个位于尚特卢公园的西边和Orge山谷东边之间的一块规模更大的场地上,场址是倾斜的,朝下看便是山谷。
