土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 科罗拉多野外摩托车俱乐部庇护所
科罗拉多野外摩托车俱乐部庇护所
发布于:2015-06-13 20:36:13 来自:建筑设计/公共建筑设计 [复制转发]
Colorado wilderness shelter motorcycle club
设计方:Black Shack Architects
位置:科罗拉多
这个野外庇护所 项目来自一个摩托车越野发烧友俱乐部的委托,为发烧友及其孩子们在科罗拉多州埃尔山专用赛道上提供一个休息站点。当地的Black Shack建筑事务所没有任何的先例可循,因此,在该项目中,建筑师们把功能、元素以及新的民居形式的创造性融合在一起。庇护所的传统概念与现代大地景观理念的融合产生一种理性的、组织有序的、新颖的设计美学。5个巨大的钢框架水平伸出几乎50英尺,只依靠一根圆形金属柱锚固着拉索,支撑着各个钢梁。
顶棚的下面是一个木框架半透明的白色体块,里面包含一个冷藏箱、可变化的空间以及厕所。其半透明的表皮能让通道接收到自然光,同时也提供必要的隐私。公共的区域中,三个面完全开放,摩托车可以从公园几乎任何方向很容易来到顶棚的阴影下停车。由当地玄武岩砌成的大火坑与项目中其它元素布置形成角度,游客能够用它生火取暖同时,也可以看到赛道上其它骑手。略微倾斜的巨大金属瓦楞顶棚能够为相当大的空间提供庇护,同时在白杨树和松树林中保持较低的姿态。
The motocross shelter is the result of a commission from a motocross-enthusiast with children who needed a rest stop in their private track in the mountains of el jebel, colorado. Local practice black shack architects did not have any precedents for such a structure so instead took to the creative blending of function, the elements, and a reinterpreted vernacular. this fusion of the classical notion of shelter and a contemporary agrarian structure lend to a rationally organized re-envisioned aesthetic. Aseries of 5 immense steel moment frame sections span almost 50 feet supported only by a round metal column anchoring tension cables spanning to each beam.
Tucked partially underneath, a wood-framed translucent white mass contains a cooler, changing area, and toilet. It’s semi-opaque skin allows the passage of natural light while providing the necessary privacy. In the open areas, which claim three full sides of the shelter, motorcycles are able to park under a shade structure with easy access from almost any direction. A large fire pit built of locally gathered basalt stones sites at an angle to the rest of the program allowing the visitors to heat up while they watch the riders on the track. The immense corrugated metal canopy contains a slight pitch enough to shelter a sizable space underneath and maintain a low profile amongst the aspens and pines.
科罗拉多野外摩托车俱乐部庇护所平面图
全部回复(3 )
  • 老建筑人生
    很给力的方案啊
    2016-07-11 13:25:11
  • 石大侠
    石大侠 板凳
    很有特点的设计,学习了。
    2016-04-07 07:41:07
公共建筑设计
51.18 万条内容 · 448 人订阅
法国班多尔赛马场设计方案
France Class dole racecourse 设计方:NOMADE Architects 位置:法国 合作方:BETEREM ingénierie 承包方:Saint-Brieuc Conurbation, Saint-Brieuc Agglomération 摄影师:Patrick Miara 这是由NOMADE Architects设计的班多尔赛马场。这个修复和扩建项目位于法国伊菲尼阿克,距市中心Saint-Brieuc约几公里。建筑师营造了一种独特的场地环境,对建筑加以改造,建立了新旧建筑之间的动态联系。整体设置中整合了一个大胆的形态类型,这是一个双重挑战,一方面旨在改善马术比赛活动的公共接待能力,另一方面提供集体活动的功能空间,如讲座、婚礼等。
