土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 德国马术竞技场设计方案
德国马术竞技场设计方案
发布于:2015-06-13 19:34:13 来自:建筑设计/公共建筑设计 [复制转发]
German equestrian arena
设计方:Kadawittfeldarchitektur
位置:德国
摄影师:Andreas Horsky
观众看台是阶梯式的建筑设计,使用的是钢筋混凝土,观众看台上是一个钢结构屋顶。屋顶的承重结构由焊接钢骨架构成,钢骨架上包裹了一层不规则四边形形状的金属片,提供支撑和遮蔽物。钢结构位于阶梯式混凝土看台后面的钢筋混凝土环梁上。屋顶由四根细长的钢柱负载,钢柱位于一楼前面的区域,并从这里通过钢筋混凝土圆柱到达地基处。地基通过螺旋钻孔桩与连梁链接在一起。
下部的看台建筑是实心结构,主要由预制构件组成。观众看台是由预制混凝土形成的阶梯式的座位。这些座位由钢筋混凝土梁支撑着,它们由钢筋混凝土横墙和圆柱负载,横墙和圆柱深入地基。一楼横墙中间的功能区是砖石结构,屋顶是预制钢筋混凝土板做成的。非承重的内墙用的是石膏做成的。竞技场主要的扩建区域是看台。为了着重强调项目的设计,所有看台的表面、楼梯和巨大的屋顶都是使用的白色,这样的设计使得整个建筑主体脱颖而出。
The specttor grandstand is designed as a step-construction of reinforced concrete, over which is a projecting steel roof construction. The load-bearing structure of the roof comprises of a welded steel frame clad by trapezoidal metal sheeting, providing bracing and cover. The steel structure rests on the rear of the stepped concrete platform on a reinforced concrete ring beam.The roof load is carried on only four slender steel columns in the front area of the ground floor and from there via reinforced-concrete round columns to the foundation. The foundations are achieved with bored piles, connected by tie beams.
The underlying grandstand construction is a solid construction comprised primarily of prefabricated components. The spectator stand is built from precast-concrete parts forming stepped seating. These are supported by reinforced concrete beams, whose load is carried by the reinforced concrete cross walls and round columns and transferred into the foundations. The functional areas on the ground floor between the cross walls are masonry construction roofed with reinforced prefab concrete slabs. The non-loadbearing interior walls are standard plaster partitions.The main player of the extension is the new grandstand. In order to emphasize the design, all surfaces of the spectator stands, the staircase, and the immense roof are a single white tone, so that the body of the structure clearly stands out.
德国马术竞技场剖面图
  • 张小二
    张小二 沙发
    谢谢楼主分享,学到了!
    2016-03-29 21:39:29
  • cmlhjcfs
    cmlhjcfs 板凳
    谢谢提供赏析!
    2016-03-29 19:30:29
公共建筑设计
51.18 万条内容 · 448 人订阅
荷兰CVV足球俱乐部设计方案
The Dutch CVV football club 设计方:MoederscheimMoonen Architects 位置:荷兰 摄影师:Luuk Kramer 荷兰建筑师MoederscheimMoonen最近为足球俱乐部设计完成了一个新的运动场地,名叫CVV足球俱乐部。这个新运动设施是荷兰,卡佩勒Couwenhoek运动公园的一部分。俱乐部建筑设计的目标是提升人们运动时的体验和运动与建筑之间的关系。建筑的一楼由立体柱基构成,作为休息室和各种各样的服务区域使用。柱基的上面是部分透明的建筑体量,里面是吧台和公共区域。这个建筑体量位于主运动场看台的上面。在这些区域上悬挂着一个面积很大的屋顶。
