土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 斯洛文尼亚皮艇俱乐部设计方案
斯洛文尼亚皮艇俱乐部设计方案
发布于:2015-06-13 21:20:13 来自:建筑设计/公共建筑设计 [复制转发]
Slovenia kayak club
设计方:Gril Kikelj Arhitekti
位置:斯洛文尼亚
项目规模:580平方米
摄影师:Courtesy of Bo?tjan Kikelj, Klavdij Kikelj
皮艇俱乐部的基本设计原理是在一个倾覆的皮艇外观的建筑上修建一个屋顶。底层平面图的形状是放在河岸上的皮艇。屋顶的尖端与河流并行,就像一条船的船尾一样。建筑外层的层级与河岸的斜坡之间非常和谐,台阶依附在建筑物的地基上。建筑物挨着沿萨维尼亚河修建的道路的层级线像等高线一样,对建筑构思进行了温和的调节。皮艇俱乐部根据不同的视角向人们展示了各种各样的环境特点。从水面上看,建筑物位于河岸的脊上。从西边和北边看,建筑物高出停车和准备皮艇用的多功能区域很多,但是这个建筑仍然用来举办大型的皮艇竞赛活动。
屋顶北面的托臂向停车的平台突出了很多,覆盖在运动前练习和船只运输的区域之上。建筑物的外墙显示了满和空之间的有趣的设计,地基和外层层级深入河岸。二楼的建筑体量外覆盖了一层落叶松护墙板,而建筑物的玻璃部分覆盖在钢塔架之上,为建筑物内部提供了光线。地下室的修建经过了设计,因为场址位于洪水易发区域。所以,这个区域是车库和放船的区域,并很容易进行疏散工作。
The basic design principle of the kayak center was to construct a shelter, a roof in the form of an overturned boat. The ground plan is shaped like a kayak on a river bank. The pointy end of the roof, parallei to the river’s flow, resembles a stern. The steps of the outdoor tiers are well harmonized with the river bank slope and attached to the buildinq’s base. The tier lines next to the paths along the Savinja are shaped like contour lines, gracefully adjusted at the same time to the architectural concept. The kayak club exhibits various features to the environment, depending on the viewpoint. From the water it seems to lie nicely on the river bank ridge, while from the west and the north it boldly towers over a multi-purpose platform of parking lot and area to prepare boats, but it is also used for events on the occasion of big kayak competitions.
The console of the roof on the northern side protrudes far over the parking platform, covering the area for prepping and transport of boats.The facade shows interesting degrees of full and void, the base and outdoor tiers grow into the river bank. The second floor volume is covered with larch wood panels, while the transparent, glass portion of the house hovers on supports of slim steel pylons. The basement program was planned so as to take into consideration the fact that the object was built on flood-prone terrain. Therefore, this area is a garage and a space for boat storage and may easily be evacuated.
斯洛文尼亚皮艇俱乐部剖面图
全部回复(3 )
  • 柴俊狗
    柴俊狗 沙发
    感谢楼主分享!
    2016-04-14 09:12:14
  • ly225323
    ly225323 板凳
    好东西!谢楼主分享!
    2016-04-13 20:17:13
公共建筑设计
51.18 万条内容 · 448 人订阅
科罗拉多野外摩托车俱乐部庇护所
Colorado wilderness shelter motorcycle club 设计方:Black Shack Architects 位置:科罗拉多 这个野外庇护所 项目来自一个摩托车越野发烧友俱乐部的委托,为发烧友及其孩子们在科罗拉多州埃尔山专用赛道上提供一个休息站点。当地的Black Shack建筑事务所没有任何的先例可循,因此,在该项目中,建筑师们把功能、元素以及新的民居形式的创造性融合在一起。庇护所的传统概念与现代大地景观理念的融合产生一种理性的、组织有序的、新颖的设计美学。5个巨大的钢框架水平伸出几乎50英尺,只依靠一根圆形金属柱锚固着拉索,支撑着各个钢梁。
