土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 捷克布拉格Nova Brumlovka休闲中心
发布于:2015-06-13 20:37:13 来自:建筑设计/公共建筑设计 [复制转发]
The Czech Nova Brumlovka leisure centre
设计方:Aulík Fi?er Architekti建筑事务所
位置:捷克 布拉格
该建筑改建于一座上世纪70年代体育场馆之上,位于商业中心,周边写字楼林立。在这座新建的健康中心其中有两层楼,其内部设有3个多功能厅,集训练,培训,和运动体育设施,健身室,25米游泳池,桑拿,按摩为一体。同时内部有2个饭店,一个邮局,还有体育用品店,酒吧以及公共卫生间。而这都可以通过商场拱廊直接到达。该建筑特别之处在于,可以大大减少周边建筑的光污染。这都得益于其外立面部玻璃面朝北并且由梯形穿孔金属片覆盖,其颜色随着日照而改变。二楼通过人行钢桥可以通往街道,使得其与外部更好连通。
NováBrumlovka is located among the office buildings of the BB Centrum complex in Prague-4 Michle on the site of an earlier sports hall from the 1970s.It is According to volume second smallest building (except Community center) in complex. Inside the newly built wellness centre are, on the two floors devoted to sport, a total of three multipurpose halls for training, courses and sport facilities, a fitness room and a 25m long swimming pool with various saunas and massage rooms.A shedroofwith a very slight pitch conceals retreating relaxation terrace that extends from the agua-zone one level below from the gaze of higher buildings around. The ground floor has tworestaurants, a post office, small shop swith sporting goods, bar and public toilets, all of them are reached from the shopping arcade. The form of the building creates optical harmony between smaller volume of the center and neighboring office buildings. Its markedly different architectural form suit sits different function. The exterior cladding is, with the exception of the expanses of glass primarily facing north. With the exception of expanses of glass, the exterior cladding is made of perforated trapezoidal sheet metal, whosecolor changes throughout the day with sunlight.The second floor of Nová Brumlovka is attached to the steel footbridge across Vysko?ilova street, making the building easily accessible even from the other part of area.
捷克Nova Brumlovka休闲中心平面图
  • yuyanhui63
    yuyanhui63 沙发
    学习了,谢谢分享。
    2016-03-29 05:20:29
  • cmlhjcfs
    cmlhjcfs 板凳
    此建筑应该是钢结构的,很有特点的建筑,谢谢提供。
    2016-03-28 23:55:28
公共建筑设计
51.18 万条内容 · 448 人订阅
奥地利滑雪度假村设计方案
Austrian ski resort 设计方:HOFRICHTER-RITTER建筑事务所 位置:奥地利 设计团队:Gernot Ritter, Veronika Hofrichter-Ritter, Wolfgang Reicht, Martin Ritter, Michael Stadler 整个建筑被一个巨大的环形结构覆盖,并由74根斜纹柱子支撑着。每根柱子能承载230吨的重量。在环形结构里建有三座相互连接的综合大楼。在南边是Planai新建的总部,有Planai-Bahnen所有的企业和子公司(360个员工)。在中央大楼是为重要合作伙伴开设的办公室,这些合作伙伴有施拉德明冬季运动事宜组织、奥地利滑雪联合会和国际滑雪联合会。北边的综合大楼的正面是由1000平方米的玻璃组成,这里供客人使用。大型运动比赛将在这里举行,电视台的拍摄工作将在一个玻璃制成的工作室中进行。工作室的质量可以经受国际审核也可与国际顶级建筑模型相媲美。
