土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 德国柏林水上活动中心设计方案
德国柏林水上活动中心设计方案
发布于:2015-06-13 20:23:13 来自:建筑设计/公共建筑设计 [复制转发]
Water Sports Centre
设计方:Oliver Mang Architekten
位置:德国
结构工程师:GSE Ingenieur-Gesellschaft mbH
机电工程师:Ingenieurbüro Zander
成本:1.250.000,- Euro
项目规模:1100.0平方米
这是由Oliver Mang Architekten设计的水上活动中心。项目位于Treptow – K?penick区的施普雷河右岸,该建筑是柏林最历史悠久的体操协会的赛艇与皮划艇之家。建筑服从功能布局,面朝着街道,对着施普雷河。船坞位于建筑与河岸码头之间。
建筑的设计与户外环境相结合。船坞与建筑的地板设计看起来就像一个折叠的混凝土环。这个环是沿街面的一面墙,也是建筑的北墙。建筑侧立面采用了透明的聚氨酯,让户外的人能看到内里停靠的船只。
整个建筑底层被用作泊船大堂,提供了180个船只的停泊区及附属区。建筑上方楼层布置了多功能俱乐部和健身室,还有宿舍、办公室、桑拿浴室、更衣室及健身浴室等。为了更好的采光和通风,建筑上方楼层设有两个天井。因此健身区没有必要设置空调。
Being located right on the river Spree’s waterside in the Treptow – K?penick area, the building is home to the rowing and the canoeing section of Berlin’s oldest gymnastics association, the “Turngemeinde in Berlin 1848 e.V.”Following the flow of functions, the building is orientated from the street side, towards the Spree River. The boat yard is situated between the building and the river with the jetty.
The exterior is combined with the design of the building. The floor of the boat yard and of the building is designed like a folded concrete loop. The loop becomes a wall at the street side and the north side of the building. The side facades are made of transparent polyurethane elements, allowing the boats inside to be seen from the outside.
Almost the entire ground floor is occupied by the boat hall, providing space for 180 boats and the affiliated workshop.The boats are carried through the gates of the boat-hall, over the yard and the jetty, into the waterIn the upper floor, the multifunctional club room and fitness areas are arranged. There are also dormitories, offices, a sauna and the changing rooms with sanitary rooms for the fitness area.
For better light and ventilation, there are two patios on the upper level. Therefore there?s no need for mechanical air conditioning in the fitness area.The building has a compact surface to avoid heating losses in the winter months and sun warming in summer. The boat hall has no heating.
柏林水上活动中心平面图
全部回复(5 )
  • yuyanhui63
    yuyanhui63 沙发
    很有思想的建筑。赞!
    2016-03-16 20:07:16
  • 大炮兵
    大炮兵 板凳
    很好很好,只不过这一行是建筑佬的天堂,结构佬的地狱啊,呜呜
    2016-03-16 15:03:16
公共建筑设计
51.18 万条内容 · 448 人订阅
德国费尔巴赫水上活动中心
Fellbach Aquatic Centre 4a Architekten GmbH 位置:德国 建筑师:4a Architekten GmbH摄影:David Matthiessen, Stuttgart这是一个刚于2013年9月15日运行的水上活动中心,里面包括了室内外泳池,水上乐园以及桑拿世界。建筑师将这一建筑结合地形很好的融入到了环境中去。项目所在地是著名的葡萄酒产地,因此建筑师以此为概念,将葡萄园的结构融入建筑,将泳池,日光浴区,游乐区等等区域分布其中。这一清晰的结构被一独立的体块所打破,如此就将泳池,水上乐园级桑拿区三个区域很好的划分开来。建筑的屋顶犹如一条大毛巾将整个功能区覆盖,建筑色彩使用了淡绿色到深红色,与葡萄园区随着四季更迭颜色变换相呼应。
