土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 俄罗斯莫斯科夏日影院设计方案
俄罗斯莫斯科夏日影院设计方案
发布于:2015-06-13 18:52:13 来自:建筑设计/公共建筑设计 [复制转发]
Summer Cinema
设计方:Wowhaus建设公司
位置:俄罗斯 莫斯科
委托人:Gorky Park
建筑时间:2012年
这个项目是由Wowhaus建设公司设计的夏日影院,它于2012年建成,位于俄罗斯的首都莫斯科。该公司并不想把项目建得很高调,他们主要想把该影院的功能和布局设计合理,使观看者更容易享受到电影本身带来的快乐。因此,他们该影院没有墙壁,没有天花板,而是建在露天的景观公园中。
时尚动感的电影总是很容易被人接受。白天该地点常常开有瑜伽公开课以及一些公开的演讲,只有在晚上才会公开播放电影。“透明”是该影院的一大特色,影院是由一系列板条围城,在影院中可以看到周围公园的池塘和夜景。
荧幕下的平台很宽敞,是由纯木制成,如果观看电影的人很多,那么这里可以减轻一些压力,开发一些辅助的小电影包厢。
We decided to make the cinema as understated as possible. The main idea was to take the functional layout of a cinema and strip it of all superfluous details – in our case, of the walls and ceiling. Thus we were able to dissolve the new building in the landscape of the park.
The Pioneer Cinema is always ready to receive guests. During the daytime the cinema area is accessible for relaxation and diverse activities ranging from yoga lessons to public lectures. And during the hours of darkness it is a venue for film screenings.
The principle of ‘transparency’ is maintained by the entrance area to the cinema, which consists of a series of slats. The role of walls is played by the high trees that surround the structure. The back rows of the cinema afford glimpses of Golitsyn Pond and a panoramic view of the park.
The wide steps of the auditorium are slightly ‘broken’ in outline in order to avoid having even lines of rows; they are faced with wood. The lightened structure of the amphitheatre has made it possible to leave a substantial part of the lawn open and use the space under the seating area as ancillary rooms.
夏日影院-10
全部回复(4 )
  • piengjfinge
    piengjfinge 沙发
    不错的影院设计,谢谢楼主分享啊
    2016-12-07 11:04:07
  • yuyanhui63
    yuyanhui63 板凳
    多谢分享,资料挺好!
    2016-04-03 05:36:03
公共建筑设计
51.18 万条内容 · 448 人订阅
荷兰阿姆斯特丹绿顶休闲馆
grass-herb roof top pavilion by marc prosman at beatrixpark 位置:荷兰 阿姆斯特丹 这是由marc prosman设计的休闲馆,位于荷兰的阿姆斯特丹的一个公园内。这个设计最大的特点是它的屋顶,上面铺满了草,这样设计的用意是用草将雨水的冲刷力减弱,并可以将水用于对屋顶上植物的浇灌,而使其郁郁葱葱。该建筑的外墙使用了旧式游泳池边的栅栏,除了是园丁的存储间、儿童监护室及园内服务点外,其他的房间都是采用这样的形式。这个公园不是一个典型的密集型公园,其中的雕塑、植被和园内景观并不拥挤。在这个建筑的屋顶采用了开放型的设计,设有一个零售服务点,服务点的外墙采用绿色与灰色相间的砖块。整个建筑的设计都十分注意了环保效应,并没有使用甲醛含量超标的建材,并通过了fsc认证的木材和能源高效、运动检测。在夏天,这座休闲馆的主人还为游客提供游船服务,从湖里游玩后进入绿色休闲馆内,一定别有一番滋味。
