土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 意大利罗马奥尔吉亚塔运动俱乐部
意大利罗马奥尔吉亚塔运动俱乐部
发布于:2015-06-13 19:17:13 来自:建筑设计/公共建筑设计 [复制转发]
Roman red tower Virginia sports club
设计方:LAD
位置:意大利 罗马
结构工程师:holzbau spa
土木工程师:teico
设计团队:michelangelo sabuzi giuliani, maria carla lini, marcello amalfitano
委托人:olgiata verde s.r.l.
这是由LAD设计的奥尔吉亚塔运动俱乐部,坐落于意大利罗马边界的一个花园城市里,周边树木繁茂。建筑是由三个不同的展馆组成,彼此之间相互连接。游客通过主入口到达行政功能区,主入口的楼梯可以到达低一层的更衣室或综合体对面的功能区。南边的建筑布置了健身房和多功能房间,而北边的建筑布置了游泳池和动感单车。室外区布置了足球场、网球场和沙滩排球场。整个运动俱乐部统一使用了意大利holzbau公司生产的回力镖造型的胶合木梁。游泳池、健身房和其他室内功能区上方的锌钛合成的屋顶能根据使用者的需要,自动调节光线。
‘the olgiata sporting club’ by LAD is located inside the woods of a garden city at the border of rome, italy. the building is made up of three different pavilions connected to one another. from the center, visitors can access administrative functions by going through the main entrance that leads to a staircase. from here, circulation provides them with the option of continuing to the locker rooms on the lower level or heading to programs that occupy opposite sides of the complex. the south contains gyms and multipurpose rooms, while the north houses swimming pools and spin bikes. outdoor spaces are accommodated by football fields, tennis courts and a beach-volley court. produced by holzbau in italy, a series of boomerang-shaped, glulam beams unifies the design as they are consistently placed throughout the sporting club. used above the swimming pool, gym, and other large interior spaces, the system hangs from a zinc-titanium roof that has the ability to adjust rays of sunlight to the needs of the inhabitants playing in areas below.
罗马奥尔吉亚塔运动俱乐部
全部回复(4 )
  • 柴俊狗
    柴俊狗 沙发
    感谢楼主分享!
    2016-04-14 09:16:14
  • yuyanhui63
    yuyanhui63 板凳
    好资料,多谢楼主分享!
    2016-04-14 06:06:14
公共建筑设计
51.18 万条内容 · 448 人订阅
成都天空别院俱乐部设计方案
Chengdu sky clause club 设计方:H?weler + Yoon Architecture 位置:四川 成都 天空别院是一个20000平方英尺的会员制俱乐部,功能包括度假别墅、办公和一些娱乐设施,利用院落和坡屋顶的形式逻辑来组织功能,在有限的界限内嵌入了好几个庭院,并利用坡屋顶来调整院落间建筑的功能空间,从上方能看到所有的院落。这个综合体并未设置一个单独的中心,而是一系列小型中心空间的有机结合,多个庭院、多条路径、多重边界形成蛛网似的结构,这样的结果是创造了一系列多层次的外部空间,也就是“借景和透景”,从这个院落也许能透过游廊观赏到另一个院落的风景。
