土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 葡萄牙figueira盛典入口设计方案
葡萄牙figueira盛典入口设计方案
发布于:2015-06-13 17:18:13 来自:建筑设计/公共建筑设计 [复制转发]
fahr0213
设计方:Fahr0213
位置:葡萄牙
这是由Fahr0213设计的葡萄牙figueira da foz盛典入口。当地的设计公司fahr0213在设计建造位于葡萄牙figueira da foz的节日盛典中担当了非常重要的角色。该项目是一个集音乐,艺术,体育,烹饪,和设计为一体的主题概念。这一设计的目标一方面希望展示这座城市的房地产布局,另一方面诠释城市的关键产业概况。Fahr0213设计设计的盛典入口是Figueira da foz地区最著名的工厂建筑,是由50000个玻璃瓶子1332平方米的蜂窝纸板构成。这一艺术作品是基于交融或者说是两种结构的“浪漫”建立的。
在这个入口处,有一个十米长的缺口,这一空间在游人进入节日盛典中作为一个缓冲的区域。两个冰山形状的欢迎式建筑物作为游客们的参照物。当然啦,这两个冰山式的建筑也是这座城市中极其精美的和独具吸引力的艺术品。这些玻璃瓶子的安装给游人们不同的重复和水平蜂窝的感官感受,突出了玻璃饼子的外在凹凸感。
marking the entranceway to a festival located in figueira da foz, portugal, the installation 'glassberg' by local designers fahr0213 acts as a point of transition. the event is a fusion between music, art, sport and gastronomy and the design enhances this theme. wanting to expose local assets and interpret key industries of the city, the designers looked to the glass bottle - figueira da foz has one of the most distinguished factories on the national and international scene. constructed from 50.000 glass bottles and 1.332 m2 of honeycomb cardboard, the artwork is conceptually based on the interaction or 'romance' between the two structures.
the entranceway consists of a 10 m long gap, which acts as a liminal space before emerging to the site of the festival. two welcoming iceberg-shaped forms serve as a point of reference for visitors, and also as an attractive piece of artwork for the city. at nighttime the materials reflect thousands of small movements generated by the festival goers into the sky through the spire shaped bottles. the 'glassberg' installation provides a sensory experience with its repetitive form and horizontal honeycomb card emphasizing the antithesis between the heaviness of each volume, contrasted by the delicate and apparent fragility of the glass bottle.
葡萄牙figueira盛典入口-12
全部回复(3 )
  • hawk9416
    hawk9416 沙发
    挺不错,学习了
    2016-03-23 11:29:23
  • yuyanhui63
    yuyanhui63 板凳
    学习啦,不断努力,不断进步.
    2016-03-23 02:22:23
公共建筑设计
51.18 万条内容 · 448 人订阅
这是本人从事的的一个酒店项目 ,建筑图中的有的,但不知道是表示啥意思
求问建筑图中这个表示啥意思?
