土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 法国巴黎疗养院设计方案
法国巴黎疗养院设计方案
发布于:2015-06-13 14:15:13 来自:建筑设计/公共建筑设计 [复制转发]
France Paris sanatorium
设计方:atelier zundel cristea
位置:法国
在设计该疗养院时,设计师仔细地考虑了适合这个疗养院所在位置的设计方案,同时又能兼顾疗养院的内部布局比例,以及建造房屋的材质。设计师在对疗养院的地理位置的再度思虑下,对院内的路线进行调整,增加了第二条入口的路线。疗养院的一楼将设有入口区域、公共空间和托儿所。而可居住的房间在第一层、第二层、第三层、第四层楼均有分布。居住场所的分配是:每个单元有12到14个床位。这种设计不仅可以有效的利用空间,便于护理人员的工作,还方便居民的日常生活。每个单元内都备有一个开放式厨房、餐厅和起居室,起居室外有一个有防护栏的阳台。
consequently, the project pays close attention to the way it fits into the site, its internal layout and proportions, and the choice of material finishes. the project involved a comprehensive rethink of the site, with access routes revised and a second entrance added. the ground floor is reserved for entrance areas, public spaces and the nursery, with inhabitable units spread across the first, second, fourth and fifth floors – distributed around the perimeter of the plan. residential accommodation is broken up into units of 12 to 14 beds. this scale not only enables efficient spatial organization, but also improves working conditions for the carers as well as the daily life of the residents. each unit features an open kitchen, a dining room and a sitting-room that opens out onto a sheltered terrace.
法国巴黎疗养院剖面图
全部回复(6 )
  • hawk9416
    hawk9416 沙发
    学习了,建筑对功能考虑很到位
    2016-03-23 11:25:23
  • yuyanhui63
    yuyanhui63 板凳
    学习啦,不断努力,不断进步.
    2016-03-23 02:24:23
公共建筑设计
51.18 万条内容 · 448 人订阅
澳大利亚Warmun老人护理中心
Australia Warmun Elders nurse Centre 设计方:Iredale Pedersen Hook Architects 位置:澳大利亚 建造方:Norbuilt 设计团队:Finn Pedersen, Adrian Iredale, Martyn Hook, Joel Fuller, Rebecca Angus, Jason Lenard, Nikki Ross
