土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 科威特Ali Mohammed T诊所设计方案
发布于:2015-06-13 13:37:13 来自:建筑设计/公共建筑设计 [复制转发]
Kuwait Ali Mohammed T clinic
设计方:AGi architects
位置:科威特
合作方:Nasser B. Abulhasan, Joaquin Pérez-Goicoechea.
委托方:科威特卫生部/ Mr. Ali Mohammad Thuniyan Al-Ghanim
设计团队:Salvador Cejudo, Stefania Rendinelli, Hanan Alkouh, Gwenola Kergall, Bruno Gomes, Ana López Cerrato.
这是由AGi architects设计的Ali Mohammed T. Al-Ghanim Clinic诊所。该项目在庭院与建筑立面交接的地方使用了独特的新模式,以解决隐私和安全等重要问题。该项目占据了整个场地,从远处看,该建筑就像是屹立于地面的巨大元素,创建了高墙堡垒般的形象,最大化保护隐私。庭院与建筑相融,以让自然光线进入整个诊所。建筑立面的概念是产生光线、视线和通风,并通过庭院进一步加强隐私性。房间都朝向封闭的外立面而布局,内部则对户内庭院开放。
From the architect. Ali Mohammed T. Al-Ghanim Clinic building by AGi architectsstands as a pioneer in the healthcare sector, where challenging issues such as privacy and security are addressed using a new model, where courtyards attached to the fa?ade are the driving element behind this unique typology.
The program occupies the entirety of the site, and from afar the building is viewed as a monolithic element solidifying its ground and creating a high walled fortress protecting from vandalism and maximizing privacy. The courtyards are carved into the building, allowing for natural light into all the clinics. The concept of the fa?ade generating light, views and ventilation is reversed; and the courtyards are brought inwards from the perimeter creating further privacy. Examination rooms have been located towards the closed outer fa?ade and opened to the interior courtyards in which common space flows.
Working directly with manufacturers and parametric processes that generate maximum areas based on minimum thicknesses, and adaptable geometries to incorporate efficient substructures have allowed creating a contemporary mesh that connects to the cultural identity of end users. An anodized and perforated metal sheet allows sufficient light to enter, constructing a veiled threshold in between exterior and internal courtyards.
Upon entering the clinic, a colorful ceramic mosaic welcomes patients. This range of colors will go with visitors during their stay at the clinic, identifying counters of each medical specialty with different colors included in the mosaic. This common practice in the hospital use is especially useful when building users belong to very different cultures, users who not only do not know the language but use different alphabets –Devanagari, Arabic or Roman-.
Due to the density and variety of the program presented in this clinic, the spaces are sectioned off into multiple self-sufficient departments, which can operate independently from one another. Internal circulation is organized in a fluid way, conceiving space as a succession of linked rooms and public areas, avoiding as much as possible the typical corridor scheme of hospital typology.The Ali Mohammed T. Al-Ghanim Clinic is viewed as an iconic progressive building, in which this vision could not have been apprehended without the generous donation of Mr. Ali Mohammad Thuniyan Al-Ghanim.
科威特Ali Mohammed T诊所平面图
  • yuyanhui63
    yuyanhui63 沙发
    学习了,未来的建筑方向.
    2016-03-25 00:41:25
  • cmlhjcfs
    cmlhjcfs 板凳
    显得很华丽,谢谢分享。
    2016-03-24 23:20:24
公共建筑设计
51.18 万条内容 · 448 人订阅
爱尔兰都柏林牙科医院设计方案
Ireland Dental Hospital 设计方:Mccullough Mulvin Architects 位置:爱尔兰 都柏林 摄影师:Christian Richters 这个项目是对五个位于都柏林中心的受保护的、连续的建筑结构的改造工程,目的是把它们改造成都柏林牙科医院的办公室、图书馆和走廊。这五个原始建筑物都位于一个平台上,其中三个是乔治王时代的艺术风格,另外两个是维多利亚式的艺术风格,因为建筑物的年龄,它们本身存在着很多问题,在改建它们时要将它们的消防安全、绝缘隔热和可达性提高到现代的标准上去。在这个过程中,要对建筑物进行仔细的工作,并在不破坏原始建筑材料、空间和涂饰的情况下使用各种方法(孔洞、壁炉、地面孔洞)去弥补原始建筑物的缺陷。
