土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 苏州康盛周庄水上俱乐部
苏州康盛周庄水上俱乐部
发布于:2015-06-12 16:48:12 来自:建筑设计/公共建筑设计 [复制转发]
Kangka Zhouzhuang Tourist Resort Aquatic Club
设计方:联创设计
位置:江苏 苏州
建筑设计负责人:钱强, Li Xiaojian, Bernd Lederle, Feng Haihua, Li Chencheng, Bi Yifei, Tanase Yo Shoji, Satoshi Morita
结构工程师:Wu Xia, Wang Rui
机电工程师:Wen Xiangjie, Wang chengxiang
这是由联创设计公司设计的“康盛周庄”水上俱乐部。水上俱乐部包括售楼处和办公楼两个部分。建筑风格体现周庄的江南水乡的地域特色,同时又不失时代特征。两个L型建筑物围合者一个内部庭院,反映了中国传统的四合院建筑空间。单坡屋顶向着湖边延伸,形成深远的挑檐,不仅体现了传统建筑的宁静致远,还塑造了优雅轻快的滨水建筑形象。
建筑师从中国南方传统建筑中获得灵感,为了体现“中国古典园林”和“江南水乡”,建筑师通过巧妙处理建筑、庭院与水的关系,并使用封闭与半封闭的庭院、半透明和实体的墙壁、水景的灵活布局等多种设计语言,展现其独特的魅力。建筑师还研发了专利产品“离瓦”,外观具有中国江南名居小青瓦的传统意象,可工业化批量生产和单元拼装。
The Site is located in the north part of Zhouzhuang which is known as “China’s First water town”. The aquatic club includes two buildings : sale house and office building of Konka, serving for 800 acres’ real estate development of the Konka Group . With sufficient research of the culture 、environment、climate and local buildings, we choose modern Chinese architectural style as design orientation, focusing on the transformation of spatial language from traditional to modern
The group of these two L-shaped buildings enclose a interior ourtyard, reflecting the ancient space philosophy of Chinese traditional courtyard buildings. Single slope roofs expand to the lake with exactly the opposite trends ,with deep overhang eaves. This not only expresses a profound tranquility of traditional architecture, but also hightlights a agile and elegant quality of waterfront buildings.
We get the concept for the design from traditional architecture of South China , in order to reflect the unique charm of “Water Town Of South China” and of“Classical Chinese Garden “ by means of ingeniously dealling with the relationship among the building, courtyard and water ,as well as using the design languages of enclosed and semi-enclosed courtyard、translucent and thoroughly walls、flexible usage of water scene. With innovatively applications of metal-tile、 clay pipes、hollow bricks and other characteristic materials, we successfully recreate the unique charm as we talked above.
A kind of self-developed metal-tile which is named “Li Wa”by our principal architect is innovatively used on the building fa?ade around the enclosed courtyard.“Li Wa” is Produced in a modern standardized industrial process, which retains the sculpt and sequence of Chinese traditional tiles. By cutting discontinuous lines on a 1mm thick galvanized steel sheet, sliding up and down the sides respectively, natural arc-shaped pieces are formed, and ultimately fixed by the reinforcing bars. The tiles which are originally used on the sloping roof of buildings are now creatively applied on the building facade, so that we can get appropriate sunshine-shading as well as energy-saving. Meanwhile, by controlling the cutting size of the steel sheet and the fixed angle of the units, we can get diverse permeability effects and various light and shadow. Combined with clay pipes on the building facade facing the lake , the curtain walls can make the vertical edge of the building vague and the profound tranquility of architecture evident.
苏州康盛周庄水上俱乐部三层平面图
  • yuyanhui63
    yuyanhui63 沙发
    学习了,未来的建筑方向.
    2016-03-25 00:46:25
  • cmlhjcfs
    cmlhjcfs 板凳
    挺漂亮的建筑,欣赏了谢谢。
    2016-03-24 22:00:24
公共建筑设计
51.18 万条内容 · 448 人订阅
德国青年俱乐部扩建设计方案
Youth-Club Extension 设计方:Bernd Zimmermann Architekten 位置:德国 结构工程师:Harry Matthies, Bietigheim-Bissingen 这是由Bernd Zimmermann Architekten设计的青年俱乐部扩建项目。该项目延续了现状的半木构的房子,设计了一个独立的建筑物,通过加入相似比例和材料,与现状建筑和周边环境相协调,同时因其现代造型凸显在环境中。
