© Clément Guillaume
该项目位于原始的郊区与当代城市环境的接壤区域,所以位置含糊不清。然而,这个地方仍然有人居住,人们在这里生活和工作。我们身处在城里,而且在这方面,我们对这片区域有着浓厚的兴趣。 From the architect. The project settles in an archetypal suburban and contemporary environment of our urban areas borders, so vague and unclear. Yet this place is still inhabited, people live and work there. We do are in town, and in this respect, we take a keen interest in this area.
© Clément Guillaume
Plan 00/底层平面图
该项目的组成部分都获得了同样的注意力:一个办公室和一个室外停车场,与现有建筑形成了一个整体。我们决定设计一个抽象的、坚固的和可观的结构。完整的停车场地面是混凝土浇筑的。此外,我们在这个区域种了100棵树。结果是得到了令人惊讶的、极简的景观。 Components of the projects are dealt with equal attention: an offices building and an outdoor car park, forming a facility with the existing building. We suggest a structure with an abstract, solid and perceptible evenness. The unbroken car park’s ground is made of raw concrete. In addition, we have planted 100 trees in this area. The result is a surprising and minimalist landscape.
© Clément Guillaume
内部空间的具体性能是根据基地与建筑的联系布置的。该建筑的中心位置被设计成了一个中庭。 The specific properties of the inner spaces are the basis of the connection between the place and its architecture. The building is adorned in its centre by an atrium.
© Clément Guillaume
在这个项目中,我们汇集了两种相反的空间类型和时间概念。一方面,办公室是日常生活中不可或缺的一部分。另一方面,有着特殊目的的特殊区域创造了中庭和景观之间的连续性:公共空间是可达的也是可见的。 We bring together two opposite types of spaces as well as two temporalities within this project. On the one hand, offices are an integral part of the everyday life. And on the other hand, specific areas with specific purposes create a continuum between the atrium and the townscape: common spaces that are both accessible and visible.
© Clément Guillaume
© Clément Guillaume
© Clément Guillaume
该建筑定义了使用和存在的逻辑性,当它展示自己的时候,从它的外立面就能感受到热情和愉悦。在室内,公共空间的实用性提供了一种新的城市环境感知,令人叹为观止。我们的建筑提供了一个身临其境的体验。 The building defines a logic of use and presence, it is welcoming and pleasant from the outside since it shows itself. Indoors, the available views from the common spaces offer a new perception of the urban environment, glorified by people’s eye. Our architecture offers a contextualized experience.
© Clément Guillaume
© Clément Guillaume
Axonometric/轴测图
CFE总部是一个生物结构。它有一个设计独特的定制外立面。这种轻巧的预制外立面是双层玻璃覆盖在木材上,且内部可开启,而外面是由铝材构成的。正立面是通过传感器来自动开启/关闭系统和遮阳篷。与中庭结合的立面允许自然通风。加热和冷却的低温地板采暖和提供使用地热能。能耗小于每年每平方米 50千瓦时。 Headquarters of the CFE is a bioclimatic structure. It has a custom-made facade with a unique design. The lightened and prefabricated facade is made of an openable double skin glass covering wood for the inside front, and aluminium for the outside front. The facade is connected through sensors to an automated open/close system and awnings. The facade combined with the atrium allows natural ventilation. Heating and cooling are provided by heating and low-temperature floors, powered by geothermal energy. Global performance is < 50kWh/m2/year.
© Clément Guillaume
© Clément Guillaume
© Clément Guillaume
© Clément Guillaume
Situation Plan/位置图
Site Plan/场地平面图
Plan 01/一层平面图
Plan 02/二层平面图
Plan 03/三层平面图
Section/剖面图
Section/剖面图
Section/剖面图
Details/细节
© Clément Guillaume
设计单位:BVAU 地理位置:法国 面积:3900.0 m2 年份:2014年 摄影:Clément Guillaume 项目管理:BVAU-Bartolo Villemard Architecture Urbanisme 工程公司:3A Architectes Associés, TN + Paysagistes, RFR, RFR element, Avel acous- tique, BETOM (TCE) 委托人:Caisse des Français de l’Étranger 项目成本: 930万欧元(税前) 环境概貌: BBC certification, Global performance is |
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
中国重庆棕榈岛设计方案客户:重庆棕榈泉房地产开发有限公司 面积:9600㎡ 时间:2012年 地点:中国,重庆 摄影:罗文、张虔希 棕榈岛项目位于重庆北部高新园区,是重庆棕榈泉地产携手HASSELL一起打造出的重庆商业建筑最新地标。HASSELL同时负责设计棕榈岛的建筑和景观。 棕榈岛建筑和景观在设计上注入了水的元素,将水和光影与建筑融成一体。从远处看,棕榈岛建筑就像浮岛一般漂浮在湖面上,格外别致亮眼。
全部回复(3 )
只看楼主 我来说两句-
仁者唯心
沙发
外形为你作主。
2016-03-21 08:43:21
yuyanhui63
板凳
令人眼前一亮!谢谢。
2016-03-21 06:00:21
加载更多回复 举报
