土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 英国雷丁循环医院设计方案
英国雷丁循环医院设计方案
发布于:2015-06-11 22:12:11 来自:建筑设计/公共建筑设计 [复制转发]
England Reading cycle of hospital
位置:英国
建筑设计:Brydenwood
雷丁循环医院是Circle Health进行的第二个项目,Circle Health是一个私人的医疗保健供应商。这个面积10100平方米的设施提供选择性的外科手术,转诊病人不仅可以包括私人,也包括英国国民健康保险制度中的患者。对Circle来说,患者的体验是非常重要的,很多注意力都被放在了建筑物的建筑设计、室内设计和患者的全部体验上。他们的目标是为病患提供酒店般的体验,而不是医院般的体验。医院坐落在英国,雷丁,根据总体规划,医院所在的场址原准备修建一栋四层楼的医院。
医院位于新的住宅开发街区、原始商业区和进入雷丁的繁忙的A33道路之间的过渡区域之中。医院被分成了两个不同的部分。在医院建筑物的东边,有一栋两层楼的砖块建筑物,里面包括服务区域和手术室,在大小、材料和规模上联系着周围的住房。这个建筑物退后到了场址的边缘上,一个野花草地和树林将它掩盖住了,并与反方向上的住房隔离开。建筑物更加引人注目的部分位于场址的西部,在规模上与南部和西部的商业发展区域相关联。
Circle Reading hospital is the second project delivered by Circle Health, a private healthcare provider. The 10,100m2 facility provides elective surgery through GP referral both on a private basis and as part of the expansion of patient choice within the NHS. Patient experience is very important to Circle and a lot of attention has been paid to the architecture, interior design and the overall patient experience. They aim to provide the experience of a hotel rather than a hospital.The hospital is located in Reading, on a site that was designated for a four storey hospital development in the area masterplan.
It sits on the transition between new residential development blocks, an existing commercial area and the busy A33 into Reading. The hospital is read in two distinct parts. To the east side, a two storey brick element contains the services areas and operating theatres, relating in size, material and scale to the surrounding housing. Set back from the edge of the site, it is screened from the housing opposite by a wild flower meadow and trees.The more striking part of the building is to the west of the site and relates in scale to the commercial development to the south and to the west
英国雷丁循环医院立面图
  • 下载原图
英国雷丁循环医院剖面图
全部回复(4 )
  • 点思设计
    点思设计 沙发
    感谢楼主 好资料!
    2016-07-02 09:54:02
  • yuyanhui63
    yuyanhui63 板凳
    感谢楼主 好资料!
    2016-07-02 05:42:02
公共建筑设计
51.18 万条内容 · 448 人订阅
瑞典马尔默急诊与传染病诊所
Emergency and infectious diseases clinic in malmo 设计方:LINK arkitektur + CF M?ller 位置:瑞典 “马尔默的斯科纳大学医院新急诊与传染病诊所”项目包括新建、改造和扩建三大任务。规划、设计和施工分期分批有序进行,并未打断医院的急疹救援工作。本建筑遵照循证医学设计的原则,重点强调光线质量。短期住院的单人病房、高水平的环境质量以及设备的重复使用,都是为了能尽量减少医疗事故。色彩、艺术设计和饰面经过设计,都有意识地散发出暖意,以创造良好的治疗环境。
