土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 奥地利Muk理疗所设计方案
奥地利Muk理疗所设计方案
发布于:2015-06-11 20:11:11 来自:建筑设计/公共建筑设计 [复制转发]
Muk / Ma hoRe
位置:奥地利
建筑设计:Ma hoRe
这是由Ma hoRe设计的Muk理疗所,位于奥地利。身为治疗师的客户的主要需求是在同一建筑中既要有确保隐私的生活空间,又要有他用于对外进行物理治疗的治疗室空间。因此,设计师将该项目分为两个部分,位于较低的部分用于工作用途,而临街的一栋两层楼主要是私人生活空间。这两个部分拥有一个共同屋顶,屋顶上有一个可供练习的实践房以及一个私人的阳台花园。屋顶的延展使它覆盖了整个西边的建筑一直联通到建筑北部形成一个小车棚。这个设计理念,使居住者既可以兼顾工作又可以享受生活。
整个住宅楼开放性很好,并且室内外的光照条件适宜。在建筑元素中,客厅里的楼梯是必不可少的,它使得整个空间气氛变得更加融洽。这个项目大部分结构采用的都是钢筋水泥土,尤其是挑梁的部分,撑起了整个设计复杂的屋顶。在居住区,阳光会通过落地窗透射在屋子里,营造出一种合适的环境。
The primal need of the client was to combine both his dwelling house and his physical therapist?s practice in one building thereby ensuring privacy for the living space and enabling the therapy rooms to be open and visible to the public.
Thus, the project is separated into two communicating volumes – the lower situated part facing the street is used for working purposes while the upper recessed part offers space for a 2-floor living area. Both volumes are combined by a common surface serving at the same time as a roof for the practice rooms and a terrace/garden for private use. The extension of this surface spans and roofs the whole west face of the building and becomes a carport in the northern part of the complex. This concept ensures independent working and living in one integrative building thereby creating a large garden which allows maximum outlook to the surrounding mountains and minimal insight from the public.
The dwelling floors appear as open areas – light-flooded with views inside and outside. Architectural elements like the stairway are experienced as furniture in the living room, thus, space becomes atmosphere.
Reinforced concrete was selected to enable an efficient construction, particularly with regard to overhanging parts of the building, and panels with duromer high-pressure laminates allowing rear ventilation were chosen to cover the face of the dwelling part of the complex. Bright glass surfaces in the ground floor of the living area permit natural light to cross the living room supporting muk’s special atmosphere.
奥地利Muk理疗所
  • 柴俊狗
    柴俊狗 沙发
    感谢楼主分享!
    2016-03-16 12:16:16
  • cmlhjcfs
    cmlhjcfs 板凳
    有味道,漂亮,谢谢提供。
    2016-03-15 23:13:15
公共建筑设计
51.18 万条内容 · 448 人订阅
美国皮肤健康研究所设计方案
The Obagi Skin Health Institute by Horst Architects 位置:美国 建筑设计:Horst 这是由Horst设计的皮肤健康研究所,这所Obagi皮肤健康研究所,位于美国加利福尼亚州拉古纳海滩。Obagi皮肤健康研究所是一家设计精巧的皮肤健康医疗机构。公司的创始人Obagi博士,是一名皮肤科医生、作家和教育家,在全世界已经做了超过200多次皮肤健康讲座。Obagi博士在过去的35年里一直致力于宣传好的护肤品以及如何才能拥有健康的皮肤。Obagi博士对建筑的要求是,希望建筑可以反映他热情帮助人们的生活态度,并提高人们对健康皮肤的关注度。两个主要墙壁内部和外部采用银灰石材料,巧妙的展示了建筑外部的质感,并与健康肤质的主题相映衬。阳光通过建筑的缝隙洒进室内,让墙壁与天花板充满美感。
