土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 西班牙莱昂ASPAYM残疾人中心
西班牙莱昂ASPAYM残疾人中心
发布于:2015-06-11 13:52:11 来自:建筑设计/公共建筑设计 [复制转发]
ASPAYM Center for persons with disabilities
设计方:Amas4建筑事物所
位置:西班牙 莱昂
竣工:2011年
首席建筑师:Javier López de Uribe, Fernando Zaparaín, Fermín Antu?a, Eduardo García
合作人: Pablo Guillén Llanos
建筑公司:Construcciones Moral Calvo S.A.
面积:1035平方米
摄影:Courtesy of Amas4arquitectura
结构:Pejarbo
业主:ASPAYM
这是由Amas4建筑事物所设计的ASPAYM残疾人中心。这个项目是开发大量自由的空间的一个系列。以庭院,减法或是空隙为形式的“空白空间”来表达建筑。通过独特的开口间接采光。ASPAYM残疾人中心建在边界明确的平地上。立面上的大量格栅产生了独特的光影和透明的艺术效果。我们可以看到一连串有意思的黑色混凝土的缝隙。这座建筑在一个很大的住区中,建筑是一个几何感很强的三角形,只有一层,平面是一个直角三角形,与基地形成一系列几何切角,建筑形成了不同高度的体块。建筑的体量和开放空间结合了庭院和广场的形状,利用了东边的平地和路旁的阿阿拉伯树胶,在内外空间的续性上产生不同的角度。这个中心有效的利用了植物的吸音效果隔绝了教室的噪音,斜的和水平光线隔断产生了透明的昏暗的内部空间,和外部的对比紧密结合。入口、大厅、咖啡馆和多种用途的空间通过一个穿入建筑北面的一个门廊联系在一起。做理疗的教室和行政区域围绕着门廊,以便在天气极端的莱昂还可以晒到最充足的阳光。
This project belongs to a series which explores massing that liberates space, and that renders protagonist that which “is not”. Such “blank space”, in the form of courtyards, subtractions, or voids, articulates the building. Light is given by indirect and unique openings. The structure is solved with large surface elements, which are manifested as enclosure. This accumulation of load-bearing mass yields great facade panes, with generate shadows and transparencies of unique artistic value. The concrete, colored black, allows us to obtain a continuity in which significant gaps open. The building occupies a triangular site with a very pronounced geometry, in an environment of large residential blocks. An orthogonal, single floor geometry is implanted in the lot, articulating a set with different traces and heights, in which interstitial spaces refer to the geometry of the site. The combination of built volumes and open spaces – in the shape of courtyards and plazas – takes advantage of the existing oriental planes and acacias on the roads nearby, generating different degrees of continuity between the interior and exterior spaces. The guarding of the center prevails, protecting the classrooms from the traffic noise, taking advantage of the shade generated by the yearly cycles of foliage. Compact exteriors contrast with a transparent and dense interior, fractured by diagonal and horizontal lights. The entrance, lobby, cafeteria and multipurpose spaces are linked through a large porch pierced on the north side of the building. The classrooms, the space for physiotherapy and the administration area are organized around it, so that their solar exposure is optimized in the extreme weather of Leon.
ASPAYM残疾人中心 -24
全部回复(3 )
  • ly225323
    ly225323 沙发
    好东西!谢楼主分享!
    2016-03-25 18:22:25
  • flh20077
    flh20077 板凳
    不错的,感谢楼主
    2016-03-12 08:49:12
公共建筑设计
51.18 万条内容 · 448 人订阅
南京鼓楼医院南扩工程设计方案
Drumtower Hospital, everybody’s garden 位置:江苏 南京 建筑设计:张万桑、瑞士Lemanarc 建筑及城市规划设计事务所建筑规模:230,000m2建筑地点:南京市鼓楼区中山北路53号 建成时间:2004 位于南京市最中心的鼓楼医院于1892年由加拿大传教士马林 Macklin医生创建,在中国医学界具有崇高的地位。直至2012年,门诊部甚至都还处在南京市主干道中山路的东侧,与医院主区仅通过地下一个狭窄的隧道相联。行医和就医均十分不便。随着区域人口的快速增加以及社会对医疗服务需求的快速上升,鼓楼医院在2004年决定在紧邻原址南侧的一块由中山路和天津路锐角相夹的约32,000 平米的夹缝地块上进行一次大规模的扩建。并对医院整体的布置和功效进行一次大扫除式的清理。
