土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 德国国家肿瘤疾病中心设计方案
德国国家肿瘤疾病中心设计方案
发布于:2015-06-11 14:07:11 来自:建筑设计/公共建筑设计 [复制转发]
The national center for tumor diseases
位置:德国
建筑设计:Behnisch Architekten
这是由Behnisch Architekten设计的海德尔堡国家肿瘤疾病中心。海德堡新建的国家肿瘤中心与以往的医院不同,在这里,病人、家属以及医护人员都可以倍感轻松。同时,建筑还为医生及其他工作人员提供了最合理的医疗环境。
为了能够更好的突显新建筑的特点,同时提供最理想的科研环境,整个建筑以中庭为中心分为四层,有利于医生和病人之间的沟通。东区和中庭相连,是海德堡的大学的门诊部,包含了三层实验室。西区则有更多宽松的自由空间,其中采用曲线结构的,是儿童医院的所在地。在项目的一二层,大楼的西侧和北入口有很多的悬臂梁,这片区域包括咨询套房、肿瘤会议室以及医务研究办公室等。
内部空间分配非常合理,友好的前台接待为患者提供了良好的心情,并引导他们找到自己的病房。技术工厂位于实验室楼下。建筑周围的地面可以收集并过滤雨水。只有在必要的情况下才会使用激活板和空调,这样可以节省运营成本。该建筑符合现代节能化的要求,且可以无缝衔接到校园诊所,同时为其服务。
The new building for the National Centre for Tumour Diseases (NCT) in Heidelberg is characterized by an open, friendly and inviting ambiance which has nothing in common with a typical hospital atmosphere. Here, patients, their relatives and friends, visitors, as well as staff can feel at ease. At the same time, the building provides an optimum environment for medical treatment and an ideal workplace for researchers, doctors, administrative and other staff.
The new building’s architecture is meant to highlight the character of the NCT, and to create an ideal setting for interdisciplinary work. Its central light-flooded atrium, extending over four floors, has been designed as a focal point fostering encounters and communication between doctors and scientists, patients and visitors. The eastern part of the building responds to the orthogonal structure and to the closed order of the adjacent ?Kopfklinik“ (head clinics), which are part of Heidelberg’s university clinics. Here, three stacked floors accommodate the laboratories. The western part of the building develops more freely, setting itself off from the stringent orthogonal structure of the environment and responding to the slight curve of the street, this way establishing visual links to the ?Kinderklinik“ (children’s clinics). Perched above is a two-storey, freely shaped volume which cantilevers over the building’s north entrance and western side. This element accommodates the consultancy suites and tumour conference areas, as well as offices for research and medical staff.
It architecturally unites the building. A generous and friendly reception area for patients offers clear orientation and leads them to the four ambulant treatment modules on levels 00 and 01.
The technical plants are located under the laboratory wing. Rain water collected around the building is filtered before reaching the ground water. The use of activated slabs and air conditioning only where necessary, optimizes costs for both the installation and operation of the air conditioning plant. The building conforms to state-of-the-art requirements for an energetically optimized building and is connected to the existing supply chain of the clinics on the campus.
国家肿瘤疾病中心
  • cmlhjcfs
    cmlhjcfs 沙发
    设计资料很好,谢谢分享。
    2016-03-09 22:26:09
公共建筑设计
51.18 万条内容 · 448 人订阅
美国加利福尼亚转化研究中心
Freidenrich Center for Translational Research设计方:WRNS Studio位置:美国 加利福尼亚 帕洛阿尔托竣工:2012年建筑面积: 30690 平方米这座转化研究中心是斯坦福大学医学院为各学科间的创新合作与临床平行研究而建的。医学中心正在着手将原来分散的教学建筑整合成更为综合完整的校园,校内将以步行路为主要道路系统,而这座研究中心是该系统工程中完成的第一座建筑。这座建筑中的研究人员原来分散在斯坦福医学院的不同办公地点,阻碍了各学科间的合作,在同一屋檐下能够促进临床医生与研究员共同研制出对病患来说更实用的治疗方法。这座面积达30690平方英尺的研究中心中可以供250名研究员使用,包括三个研究组织:临床试验研究——为斯坦福目前几个临床研究提供支持;癌症临床试验办公室;光谱学研究。这一研究中心是斯坦福大学内一个独立的研究机构,学校要求这座新建筑要与医学院校园的风格相一致,而该设计正是以现代的方式对医学院的风格进行了解读,采用了石材、赤陶土、玻璃和木材作为主要材料;深深的游廊和檐口,创造出连续的外部空间。周围的空间非常开阔,与相邻建筑间留有相当的距离,主入口采用了赤陶土板装饰墙壁,上方的石墙形成了游廊,将人们引入一个安静的入口庭院。二层平台上可以俯瞰这个庭院的全貌,中庭的室外楼梯连接着建筑中所有楼层,门诊区位于一层,透过百叶欣赏庭院中丰茂的植被。这些室外公共空间是很有价值的,可作为研究人员工作之余的休憩场所,同时也延续了斯坦福大学优雅的景观传统。最上面的两层作为研究室、办公室和临床实验区。
