© Simon Garcia
该别墅位于布拉瓦海岸的中心,从这里能够欣赏美丽的海湾景观。 From the architect. Description A house situated in the heart of the Costa Brava with incredible views to a coast bay.
© Simon Garcia
该设计的挑战在于将大的项目放进体量中,还要和这里的自然景观形成对比。因此我们提议放置一些立方体,就像是随意投放的,又像从天而降,但最后它们都被安置在了这个扇形地块。 The challenge was to fit a big program in a volume with some formal contrast with the nature of the place. So we propose some cubes placed as if they were randomly thrown, like if they were fallen from the sky, but finally they really derive from the fan-shape of the plot.
© Simon Garcia
这些立方体建筑有相同的7×7米的尺寸。它们一侧完全敞开,以便欣赏海景并且有最好的向阳角度,所以,为了避免阳光直射,它们用非常特殊的大百叶窗来保护,这些百叶窗通过液压系统来操作。这些立方体的位置和结构与别墅的其余层搭配很和谐。 Those cubes have the same size: 7 by 7 meters. They are absolutely open by one side, in order to have the sea views and the best solar orientation, even that they are protected by those very special big blinds (operated by hydraulic system). The situation and position of those cubes project the directives of the rest of the levels of the house.
First Floor Plan/一层平面图
© Simon Garcia
下层平面有部分延伸出来,和草地融合,创造了一个敞向大海的大空间。 一层是主楼层,是最重要的使用部分,它向外部平台、泳池和花园开放。三个露台有助于增加一层的自然采光和通风,也有助于分配不同空间的用途:客房,大门,书房,厨房和主客厅。 Under levels have been integrated in the field with a big spaces opening to the sea. Ground floor that is the main level is situating the most important used pieces in open and direct connection with the outside terraces, swimming-pool and gardens. Three patios help to increase natural lighting and ventilation of this level. Also the serve to distribute the uses of the different spaces: guest apartment, main entrance and study, or the kitchen area and main living room.
© Simon Garcia
较低层和蒲草庭院相通,庭院用微型沙丘设计。这里我们能发现温泉、澡堂和休息区。单独设有服务人员房间,供管家和保姆使用。 Lower level is in contact with the grass garden designed in micro-dunes. Here we can find the Spa and Hammam and a rest area. Separated there is also an apartment for the service of the house (housekeeper, babysitter).
Floor Plan/平面图
© Simon Garcia
立面采用两种主要材料: —石灰石,用于较高体量的通风立面,给予别墅高贵的特点 —装填石头的石笼,用于别墅地下室以及花园的墙壁和防护 Two main materials have been proposed for the façades: - Travertine stone of the ventilated façade for the upper volumes, that is giving a noble character to this part of the house - And the gabions filled with stones of the area, used for the basement of the house and for the walls and protections of the garden.
© Simon Garcia
项目另一重要方面是服从可持续建筑原则,在别墅的设计和材料的选择中采取节能措施。 泳池多出的部分被水覆盖,它可作为一个边缘和保护措施。 Another important aspect of the Project is the compliance to accomplish the principles of sustainable architecture, taking energy-saving measures into the design of the house and in the selection of the materials. Swimming-pool is overflow as an infinity pool and protected by an automatic cover.
© Simon Garcia
© Simon Garcia
Ground Floor Plan/底层平面图
Floor Plan/平面图
Detail/细节
Detail/细节
建筑设计:DOSARQUITECTES 项目位置:西班牙 吉罗纳 项目面积:2000.0平方米 摄 影:Simon Garcia 结构设计合作者:Amanda Colom Calsina 技术建筑师:Lluís Serrat Tarrés 营造商:Rehabilitació i Construcció Salichs S.A. 设备:SINOPHOS GROUP |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
中国浙江长兴被动式住宅 BRUCK©Peter Ruge Architekten 项目简介 新型低能耗样板公寓大楼布鲁克,中国浙江省长兴 最近,在中国的南方正在进行被动式房屋的建造,房屋的设计者Peter Ruge 建筑师事务所通过对被动式房屋的设计为可持续性房屋设立了新的标准。与中国传统的住宅建筑相比,被动式房屋可以节省95%的能耗。被动式房屋“Bruck”是首次在具有潮湿、温暖、南部气候的国家对这一类型的房屋进行的尝试。项目将于2014年5月竣工。
只看楼主 我来说两句 抢板凳
