© Meero
这个30平方米的公寓由建筑师Richard Guilbault 改造,房屋最初分为4个很暗的房间,难以进行装修。房子现在属于一对年轻夫妇,全面改造的目的是创建一个有生气的明亮客厅,优化私人房间的使用,并且尽可能使存储空间最大化。 From the architect. This 30 sqm flat transformed by the architect Richard Guilbault was first divided into 4 very dark rooms difficult to fit out. Today occupied by a young couple, the ambition of this full update was to create a dynamical and bright living room, to optimize the use of the private rooms and to maximize the possibility of storage space.
© Meero
在新的布局中,客厅占据2/3的居住面积,而不是以前的1/3,光线通过4扇窗户照进公寓。定制的浴室很舒适,仅占2.3平方米。新卧室素雅温馨,隐藏了很多储物柜,将床抬起就产生了非典型的舒适的空间,就像一个小木屋。宽的推拉门将卧室和客厅隔开。 With the new space organization, the living room takes up 2/3 of the living surface area (instead of 1/3 before) and enjoys the light coming from the 4 windows of the flat. The custom-made bathroom is comfortable and takes up only 2.3 sqm. Discreet and intimate, the new sleeping space hides a voluminous storage chest; the raising of the bed makes an atypical and comfortable space, like a cabin; the wide sliding door allows to be isolated from the living room.
© Meero
存储空间从入口处沿着整个公寓长度布满长长的墙壁。空间不时被打断,一会是4个壁龛,一会是白色和桦木原色胶合板之间的对比。公寓的构架相当于多用途家具,吸纳公寓的所有技术需求和业主的不同需求:配电板,存储间,家用电器,食品室,冰箱,酒窖,电视,更衣室 … Since the entrance, a long wall of storage is running along the complete length of the flat. It is punctuated by 4 niches and a game of contrast between the white and birch plywood front panels. This multipurpose piece of furniture, the backbone of the flat, absorbs all the technical needs of the flat and the different needs of the owners: electric panel, storage, appliances, pantry, fridge, wine cellar, TV, dressing room…
Floor Plan/平面图
© Meero
在这个小小区域,一切都深思熟虑以求洁净雅致。白色表面承载着像白桦木这样更自然的衬底,或者更形象的衬底,像水泥花砖和采用变化多端的马赛克瓷砖的厨房餐柜。 In this small area, everything is deliberately pure and refined. The white surfaces are a carrier for more natural substrates like birchwood or more graphic ones like the cement tiles and the kitchen credenza in kaleidoscope mosaic.
© Meero
旧墙壁的表面连接用白色混凝土灌注来突出,讲述了公寓的历史。生动线条的创造活跃了这个巴黎公寓的经典木地板。 The apparent connections of the former walls have been highlighted by a white concrete filling to tell the history of the flat. The creation of graphic lines enliven a classic wood floor in Parisian flat.
© Meero
© Meero
© Meero
© Meero
© Meero
© Meero
© Meero
Section/剖面图
Section/剖面图
建筑设计:Richard Guilbault 项目位置:法国巴黎 项目面积:30.0平方米 项目时间:2015年 摄 影:Meero |
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
意大利都灵维亚艾法利6号公馆© Piero Ottaviano 6号公馆,Palazzo Valperga Galleani宫的修复项目,是对建筑拯救、尊重文化遗产、技术、优雅和美感的最好表现之一。由Building Engineering承担的本次整修和发展,目的在于对这个重要的历史及建筑产业进行大幅功能性改造,尽管它在上个世纪所受到的损毁导致了其原本住宅意义的缺失。
只看楼主 我来说两句 抢板凳
