土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 法国滨海拉塞纳“红线”公寓
法国滨海拉塞纳“红线”公寓
发布于:2015-06-03 10:44:03 来自:建筑设计/居住建筑设计 [复制转发]
从草图阶段直至完工
从住区能够随时看到迷人海景的想法从第一次草图设计的第一笔落下便开始指引设计,并在深入设计方案过程中源源不断地给我们灵感。然而,这个项目的设计本不能和一个单独的坚固的体块很好的融合,因为它会遮挡周边住户的视线,并且在这座住宅楼里的59套公寓中有一半的住户会被阻挡而看不到迷人的海景风光。以场地踏勘为出发点,我们把建筑朝向北面——面对土伦湾的海湾风光,建筑沿着天井,从东到西被分成了两部分。
From the architect. From sketch to completion
The obsession to always be able to see the sea from where we live on the coast guides our pens from the first sketches and never fails to inspire another way of building. As such the Redline plot could not have tolerated a single, solid block, which would have obstructed the views of the surrounding housing and prevented half of the 59 housing units from having a view of the sea. Using this site survey as a starting point, and setting our sights on the north where the Bay of Toulon is curled up, a building that splits in two along a patio running from east to west was drawn.
这样的东西向空间组织为公寓提供了多样的便利设施,使得项目前后方向都可以获得很好的景观,并且,庭院的设计也有助于通风和观景。观景平台,这种城市中常见的建筑形式作为观光点成为了项目的特色。
This east/west spatial organisation grants a multiplicity of amenities with apartments that have both front and rear facing views and an outdoor patio designed to ventilate and make the most of the vista. The belvedere, a sort of socially acceptable window into the city, serves as a vantage and lookout point.
每个世纪都有它的重建时期。在船坞关闭(1989)的25年后, 滨海拉塞讷(La Seyne-sur-Mer)这座城市正在经历一场实实在在的全方位改造建设,尤其是滨海旅游业。这种经济发展推动着 瓦尔河度假区(Var resort)重新开发荒地和复苏它在沿海的城市空间——沿着海岸线形成一条辉煌的杜桑-梅尔(Toussaint-Merle)长廊。
Every century has its period of reconstruction. Twenty-five years after the closure of the shipyards (1989), La Seyne-sur-Mer is undergoing a real reconversion to diversify its activities, particularly beach tourism. This economic development is encouraging the Var resort to redevelop its wasteland and restore its urban spaces on the coast along which runs the splendid Toussaint-Merle promenade.
这座红线住宅包含了59套公寓。户型涵盖了小型工作室到有5个房间的套房。这个建筑是城市复兴的一部分。面向土伦和欧洲最大的海湾之一,Vignettes的红线住宅因为在旧造船厂遗址上将要建成秋季公园而略微后退。这个住宅基础包括三个独立的部分,分别是一个锻造雕饰过的巨大混凝土和在上面竖立的两翼。
The Redline – 59 apartments ranging from studios to 5-rooms – is a part of this urban revival. Facing towards Toulon and the Bay of Vignettes, one of the largest in Europe, the Redline is set slightly back from the future Autumn Garden located on the site of the former shipyards. It comprises three separate parts with its base, a forged and sculpted mass of concrete, onto which two wings have been erected.
考虑到用户和居住环境,该项目做出了几种应对:
满足舒适性的要求:所有的公寓都有前后的自然景观并且实现自然通风,因而这个住宅没有真正意义上的“背面”。平台合适的宽度与进深在向海的一面为人们提供了一览无余的海景风光。楼梯间的天桥由预制混凝土铸成。电梯只布置在了西面的住宅楼里,而通过这些天桥便可以到达东面的公寓。
The project may also be differentiated in its consideration for its users and the environment, satisfying:
Comfort requirements: all apartments have front and rear facing views and are naturally ventilated so there is no “rear façade” as such. The width and depth of the terraces offer clear and unobstructed views out onto the seafront. The aerial walkways are made of pre-stressed concrete; they enable access to the east apartments, as the lifts are located in the west building.
此住区的特权:建筑的外立面被储存空间各个分开,所以从街上看,建筑的外观整洁美观。
The prerogatives of the town: the external façades are punctuated with separations, which serve as storage cupboards so as to avoid any visual pollution from the streets.
多样性标准与可持续发展:布满植物的中央庭院花园搭筑在混凝土板上(抗渗透,排水流畅,耐风蚀)。而在这混凝土板下是通风良好的停车场和商业场所。
Standards of diversity and sustainable development: the central patio has been landscaped onto a concrete slab (impermeability, drainage, weather-proofing). Below this there is a well-ventilated parking lot and business premises on the ground floor.
在周边秋季园和土伦湾美景的环抱下,开敞的露台、怡人的观景楼以及静谧的花园径道吸引了观光者的目光。
The patio, belvedere and walkways invite contemplation of the landscape – on one side the Autumn Garden and on the other the Bay of Toulon.
建筑设计:Pietri Architectes
位置:法国,滨海拉塞纳
面积:4300.0平方米
年份:2014年
摄影:由Pietri建筑师团队提供
项目团队:Pietri architects, BET Yves Garnier, BET Qualiconsult, Marseille aménagement, Néo Paysages, Veritas
Architects: Pietri Architectes
Area: 4300.0 sqm
Year: 2014
Photographs: Courtesy of Pietri Architectes
Project Team: Pietri architects, BET Yves Garnier, BET Qualiconsult, Marseille aménagement, Néo Paysages, Veritas
居住建筑设计
28.74 万条内容 · 423 人订阅
巴西伯南布哥建筑师的房子
© Antônio Preggo 当你设计你自己的家时,常常会发现很多问题,各种条件都需要纳入考虑中。 在设计过程中没有客户干扰,设计师便可以按照信仰来创作,去实现自己的观点,甚至可以做自我意愿的小白鼠。
