土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 艺象国际青年旅舍设计方案
艺象国际青年旅舍设计方案
发布于:2015-06-03 09:35:03 来自:建筑设计/居住建筑设计 [复制转发]
© Chaos.Z
艺象(iD TOWN)国际青年旅舍,位于海边群山的山顶之上,是原来鸿华印染厂居住区的宿舍楼之一,代表着深圳工业化与开放重组政策后的第一批产业工人的安置区。
From the architect. Youth Hotel of iD Town, on the hilltop of the seaside valley, was originally served as one of the dormitory building in Honghua Dying Factory’s residential area, representing the settlements of the first batch of immigrant labors after the open-reform policy and industrialization that firstly took place in Shenzhen.
© Chaos.Z
© Chaos.Z
© Chaos.Z
改造过程主要包括两个空间的变化:首先是以新的酒店基础设施作为中央走廊的配套,以方便新的居住单位使用;二是在现有立面上安装了预制钢式的开放盒子,在建筑与周围景观之间创造出更具动态交互的空间。首层作为多功能的社交空间,囊括了接待处、咖啡厅、开放式厨房和公共空间等设施。通过对原来结构轻微的改动,这些功能便一一呈现,互相联系。
The renovation process mainly consists of two spatial actions: firstly equipping the central corridor with new hotel infrastructure to facilitate the new living units, and secondly installing a sequence of prefab steel opening box on the existing facade to create a more dynamic interaction between the building and the surrounding nature. The ground floor functions as a multi-purpose social space with a variety of facilities containing reception, cafe, open kitchen and common space. By a subtle alteration of the original structure this handful of functions dynamically relate to one and other.
底层平面图
居住单元位于2楼到4楼,通过对原有结构的微小改动重新焕发生机,为原来的空间组成带来了一个全新的视角。所有这些细微的,但有影响力的改变给这个曾经荒废的建筑创造了一个新的气息。
The living units, located from the 2nd floor to the 4th, brought back to life by small adaptations of the original framework bringing the opportunity of a new perspective to the original spatial composition. All these subtle but influential alterations creates a new breath to this once ruined structure.
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
© Chaos.Z
平面图
剖面图
建筑设计:源计划工作室
地点:中国广东省深圳市
主创建筑师: 何健翔/蒋滢
设计团队:Mincong Deng, Jingyu DONG, xiaolin CHEN
面积:1800.0 平方米
年份:2014年
摄影:Chaos.Z
Architects: O-office Architects
Architect In Charge: Jianxiang HE, Ying JIANG
Design Team: Mincong Deng, Jingyu DONG, xiaolin CHEN
Area: 1800.0 sqm
Year: 2014
Photographs: Chaos.Z
居住建筑设计
28.74 万条内容 · 423 人订阅
荷兰赖森SR别墅设计方案
© Luuk Kramer 旧屋被规划保留往往是因为屋体本身的再循环能力。它们一般都有高高的天花板,良好的采光,宽阔的房间和大门。但还有一个重要原因使其免遭被拆的厄运:我们爱它们,因为它们本身设计好或者用材良好。保留你的房屋,或者新建一座可供长期使用的房屋,让你的房屋更加环保。
