土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 日本东京低调的华丽--KUTO大楼
日本东京低调的华丽--KUTO大楼
发布于:2015-06-03 10:07:03 来自:建筑设计/公共建筑设计 [复制转发]
© Daici Ano
© Daici Ano
这个复杂的建筑位于东京市中心的一条购物街,这是个曾经繁华的购物街,后来失去了往日的活力。有轨电车的运行轨道与购物街平行,与电车一侧连接的道路正在拓宽,同时这条街上的许多建筑开始重建,本次项目也是其中之一。KURO Building 的一楼作为一间面食餐厅,二楼被用作自用空间,三楼、四楼则用于住宅出租。
From the architect. The complex building on a shopping street of the Tokyo downtown area. This shopping street is losing once activity. The streetcar is running to this shopping street in parallel. In connection with the road of the side of a streetcar being widened, many buildings on this shopping street start to rebuild. This building is also one of them. The second floor is used as the house of a client, the first floor as noodle shop of a client, and the third and the fourth floor as the rental housing.
© Daici Ano
业主从小就在这个地方生活,所以希望该建筑有一种存在感,既不要被周围的环境所淹没,也不要太过引人注目。我们的目标是使建筑适度突出,并能在很长一段时间里始终保持它的存在感。
The client lives in this area from childhood. While needing a presence which is not buried under surroundings, too much conspicuousness is not desirable. We aim for the building which is moderately conspicuous, and can maintain the presence even if it passes through time.
© Daici Ano
© Daici Ano
© Daici Ano
建筑的表面动态不均匀地分布着一些小型的檐口,既可以达到遮阴效果,又具有防水功能。立面外挂一种OSB 定向纤维板(Oriented Strand Board,胶合板的一种),用结合剂连接,使立面呈現出精致的质感。建筑会产生阴影,并随着入射角度的改变而改变,有时落入外挑的檐口,有时又仿佛从檐口流出。
Dynamic unevenness by the small eaves for a shade and a rain-cover. Detailed unevenness by the transferred texture of OSB plywood. Fine unevenness by the cement. The shade of the sunlight which changes every moment, falls and flows into these unevenness.
© Daici Ano
剖面图
黑影重叠的混凝土立面绘制出深浅不一的黑色,给建筑增添了多样的立面视觉效果。这样的结构使建筑在不同的条件下(不同的角度,时间和距离),都会表现出不同的样子。它是这个无序小镇的一道独特的风景线,而不是被淹没在环境中。
The black shade overlaps panels of a concrete which painted different black, and gives various expression to the building. The construction can get a peculiar expression under each condition every angle,time and distance.
It can also get the presence adapted oneself to the scenery of the disordered town, and not buried to the surroundings.
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
© Daici Ano
平面图
平面图
平面图
平面图
北立面
南立面
细节
图解
© Daici Ano
建筑设计:KINO建筑师事务所
地点:日本东京
面积:75.0平方米
时间:2013年
摄影:Daici Ano
Architects: KINO Architects
Area: 75.0 sqm
Year: 2013
Photographs: Daici Ano
全部回复(5 )
  • sheji024
    sheji024 沙发
    感谢楼主分享好资料
    2016-08-17 08:22:17
  • 仁者唯心
    仁者唯心 板凳
    这符合他们的个性。
    2016-02-22 10:29:22
公共建筑设计
51.18 万条内容 · 448 人订阅
土耳其科尼亚城市体育馆
© Ket Kolektif 科尼亚城市体育馆坐落在城市北部,距离市中心9km,占地面积约450000㎡。场馆内部包含一个足球运动场、一个游泳馆、一个自行车赛车场和一个广场。人们可以通过铁路运输系统、自驾、公共交通等多种方式到达。科尼亚城市体育馆是科尼亚城市文化符号与现代建筑相互碰撞的产物。建筑的外立面白绿相间的颜色正是代表了这个城市的足球队。
