土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 美国加州三藩市常春藤街300号住宅
美国加州三藩市常春藤街300号住宅
发布于:2015-06-01 12:31:01 来自:建筑设计/居住建筑设计 [复制转发]
城市商品房、 餐厅和商店的综合使用修复了因城市中心道路拆除所引起的区域机理的破坏。设计平衡了内外环境: 既满足了社区居民对高质量的、 现代的、 静谧的居所的要求,同时为社区配备充满活力的零售商店,行人过道,在尺度和材质上都尊重周围建筑物。
From the architect. This mixed-use development of urban market-rate homes, restaurants and shops continues the repair of the neighborhood fabric damaged by the removal of the Central Freeway. The design was developed as a balance of inside and out: equally addressing the needs of residents for high- quality, modern, peaceful homes with the needs of the community for vibrant retail, a place for pedestrians, and a texture and scale that respects the surrounding buildings.
设计的开始就考虑到项目该如何与公共空间相衔接,采用的是将项目从原先位置"拉回"的谨慎的策略,有效地释放公共空间打造舒适和 人性化的空间。该项目通过设计灵活利用并加宽的人行道和一个方便的入口将对边缘区的利用最大化,鼓励商用空间和行人进驻常春藤街。
The beginning basis of the design was a consideration of how the building would touch the public space, and the strategy used throughout is the ju- dicious “drawing back” of the building from the property line, effectively re- turning space to the public realm to create the comfortable, human-scaled edges. This building maximizes the site edge with lively uses, widened sidewalks, and a gracious entry sequence, encouraging retail spaces and residential stoops to connect outward to the street.
街角酒吧被强化,产生如同Hayes Valley中心的繁忙的单行道的感觉。在这条尺度较小的横巷里,商铺装饰一致的玻璃横窗,暗示了小区的类型性,并能通过该装饰让日光照入店中。
An emphasis on the corner bays creates a gateway feeling as the busy one-way traffic approaches the heart of Hayes Valley. At a smaller scale, transom windows line the retail arcade, referencing the common typology of the neighborhood and bringing daylight into the shops.
主入口在拐角处,是该项目人气最旺的一面,在常春藤大街更小、 更安静的一侧。入口成为一个引导居民从熙熙攘攘的高夫街遁入的"缓冲"入口,。
The main entrance is around the corner from the building’s most public face, on the smaller and quieter Ivy Street. The approach to this entrance has been arranged as a “decompression” sequence that guides residents from the bustle of Gough Street towards the sanctuary of the building.
在内部,建筑单元设计现代简约,通过落地窗获得最大化的视野并延续与外部的连接。如项目一楼从边缘收入内部的设计,以创建额外的公共空间,上述单位延伸,拉近了私人空间与繁忙的人行道的距离。
Inside, units are designed with modern simplicity, maximizing views with floor-to-ceiling windows and continuing the connection to outside. Just as the ground floor of the building has been pulled in away from the edge to create additional public space, the units above extend, pushing private space out over the busy sidewalks.
街角的邻里模式为住户们创造了一个附赠的独一无二的空间。屋顶有户外趣味厨房、 一个奢华的普罗梯亚木花园和一个消磨时间的庭院。外围圈的一盆盆竹子将空间隔开,居民可以用各种绿植装饰庭院。
The neighborhood-inspired pattern of bays creates unique edges for the units, adding interest. The rooftop has an outdoor entertaining kitchen, a lavish protea garden, and a patio for lounging. A perimeter of bamboo defines the common space, which is lined with planters available to residents for gardening.
小尺度的常春藤街,因为高度限制,项目改变规划并变成一排三层楼高的联排别墅。将花圃移入街道停车场之间,将项目面积从旧址中缩水几英尺,将一层起居室移离地面,建造在室内门廊之上。设计加宽了人行道,缓冲了联排式住宅和完全的公共领域之间的冲突。
On the smaller scaled Ivy Street, as height limits drop, the building chang- es tone and becomes a row of three-story townhouses. By moving the trees into planters between the street parking, pulling the building a few feet back from the property line, and lifting the first living floor off street level via indoor stoops, the design widened the sidewalk for pedestrians and buffered the townhouses from the fully public realm.
建筑设计:David Baker Architects
项目地点:美国加州 三藩市常春藤街300号
项目年份:2014
摄影:Bruce Damonte
开发商:Ivy Grove Partners
承包商:Cahill Construction
景观设计:Fletcher Studio
结构工程:Murphy Burr Curry
土木工程:Sandis
照明设计:Horton Lees Brogden
多媒体设备:Robison Engineering
设计/制作:Pacassa Studios
户外装置:OHIO Design
Architects: David Baker Architects
Year: 2014
Photographs: Bruce Damonte
Developer: Ivy Grove Partners
Contractor: Cahill Construction
Landscape: Fletcher Studio
Structural Engineer: Murphy Burr Curry
Civil Engineer: Sandis
Lighting Designer: Horton Lees Brogden
Mep: Robison Engineering
Design/Fabrication: Pacassa Studios
Outdoor Furnishings: OHIO Design
居住建筑设计
28.74 万条内容 · 423 人订阅
韩国首尔松坡微住宅设计
Courtesy of SsD 城市密度和住宅成本已经是世界性的问题。尽管居住单元类型变小了,但是微住宅很有可能会成为几乎没有社会价值的临时过夜庇护所。通过挖掘最大的房屋面积比和最大的围护结构之间的差异,松坡微住宅提供了一种新的类型,拓展出了更多的公共空间,如半公共走廊,阳台,以及视觉延伸。
