© Jose Hevia
这个项目可以通过5个有趣的点描述。 From the architect. The work can be described through 5 interest points.
© Jose Hevia
环境和形状 该建筑位于工业和住宅区之间的中间位置,毗邻现已废弃的帕尔马旧监狱。其平面形状是梯形的,并且建筑最大化的利用了基地的可使用面积,这也是客户的要求。其建筑体量与环境不断对话,混合了“国际风格”和马洛卡传统农村建筑的建筑风格。 -Environment and Shape The building is located in an intermediate location between and industrial and a residential area, adjoining the old prison in Palma, nowadays abandoned. The plot is trapezoidal,and the building adapts to it using the maximum surface area allowed, as it was required by the client. Its volumetric architecture is a constant dialogue with the environment, blending the architecture of ‘International Style’ and traditional rural buildings in Mallorca.
© Jose Hevia
© Jose Hevia
结构和构造系统 该结构是由金属支柱和复合板组成。支柱连接到外部结束,这使得整个地板除了垂直的核心筒部分都是一体的。在这种方式中,内部分布不受结构的干扰,允许其重新排布空间。G.H.A.S.系统被用于密封建筑表面,大大提高建筑物的热性能和机械性能。 -Structure and Constructive System The structure is composed of metallic pillars and composite slabs. The pillars are attached to the external closure, which allows having the entire floor available except the vertical communication core. In this way, the internal distribution does not have structural interferences, allowing rearrangement of spaces. G.H.A.S. system has been used to execute the envelope, remarkably improving the thermal and mechanical performance of the building.
© Jose Hevia
外立面、构图和灯光 主要的入口位于大悬挑遮阳系统下面,玻璃幕墙占据了主立面的一整块墙体,起到了遮掩作用。一个开启的玻璃门表明这里是出入口,并且让光线撒入接待厅。 -Façade, Composition and Light The main access, located under a big marquee, is built by a glass wall that occupies the main façade’s length, which is mainly blind. A single opening in this glass façade indicates the entrance and lets the light invade the reception.
© Jose Hevia
其他的3个立面的设计满足了空间上光线和通风的要求。为此,只需要三种开口即可(尺寸50×240cm,100×240cm,150×240cm)。 The composition of the other 3 façades has been designed following the lightning and ventilation requirements in each one of the spaces. To do so, only three kinds of openings were needed (dimensions 50×240 cm, 100×240 cm and 150×240 cm).
© Jose Hevia
© Jose Hevia
Section AA A-A/剖面图
这个项目主要需要实现的目标之一就是为手术室提供日光,这里空间通常是封闭的并且缺乏日光。为了达到这个要求,在这些房间里面设计了可以向北打开的天窗,允许漫射光进入室内,而不打扰或影响日常工作。该建筑一层的墙面贴上了瓷砖,带来了基数效应,并使用不同质感和亮度的瓷砖。这也有利于日常维护。 One of the main objectives of the project was providing the operating theatres with daylight, spaces which are usually closed and lack of it. In order to achieve this objective, North-oriented skylights have been opened in these rooms, allowing the entrance of diffuse light without bothering or interfering with the daily work. The building walls are tiled on the ground floor, bringing a base effect, with a different texture and brightness. It also facilitates routine maintenance works.
© Jose Hevia
© Jose Hevia
白色是建筑的内外空间的主要颜色。这个单色处理强调整洁和地中海风格。 White is the predominant colour in the interior and exterior of the building. This monochromatic treatment emphasizes its tidiness and Mediterranean character.
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
© Jose Hevia
Basement Floor Plan/地下层平面图
Ground Floor Plan/底层平面图
First Floor Plan/一层平面图
Roof Plan/顶层平面图
建筑设计:Estudi E. Torres Pujol 地址:西班牙,巴利阿里群岛,帕尔马 建筑主要负责人:Esteve Torres Pujol 面积:1538.0平方米 年份:2014年 建筑摄影:Jose Hevia 项目管理: ARCOFITEC 执行董事: Antonio J. Sanchez, David Seguí Leggett 设备: Joaquín Canet y Miquel Llinàs – Engineers Assesors 结构: Joan Fortuny 安全协调: Jaume Oliver 地形: Santiago Ginard 岩石工程: Geoma 3 D: Santi Domínguez Maestro 构造: Contratas Bartolomé Ramón S.A. 暖通空调和管道安装: Clima Insular S.L. 电器安装: Easa Electrica Arias S.A. 通信工程: Level Electronics S.L. Architects: Estudi E. Torres Pujol Location: Palma, Balearic Islands, Spain Architect In Charge: Esteve Torres Pujol Area: 1538.0 sqm Year: 2014 Photographs: Jose Hevia Project Management: ARCOFITEC Directorate Of Enforcement: Antonio J. Sanchez, David Seguí Leggett Facilities: Joaquín Canet y Miquel Llinàs – Engineers Assesors Structure: Joan Fortuny Security Coordination: Jaume Oliver Topography: Santiago Ginard Geotechnical: Geoma 3 D: Santi Domínguez Maestro Constructor: Contratas Bartolomé Ramón S.A. Hvac And Plumbing Installation: Clima Insular S.L. Electrical Installation: Easa Electrica Arias S.A. Telecomunications: Level Electronics S.L. |
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
融合多曲面砖墙与纯白色几何形状的精品酒店photo © wison tungthunya Onion建筑事务所设计的“撒拉城府”是一座拥有26个房间的精品酒店,坐落在泰国湄南河畔风景如画的老首都。1353年第一任君主建成的phutthai sawan寺成为涵盖餐厅和河边套房的风景。酒店的主入口在U-thong路边一棵撒拉树旁,是长长的砖墙立面上的一个铁门,引导住客通向有着低矮木质屋顶的前台和双层空间的艺术画廊。
只看楼主 我来说两句 抢板凳回复 举报
