image © derek swalwell
一个两层的庭院空间坐落在新加坡这座半独立住宅的中心。在HYLA建筑事务所的设计下,院落的第一层围绕一棵种植在以木质框架围合成盒装的中庭中心的鸡蛋花树展开。住宅的第二层位于餐饮空间之上、主卧室的前方,同时面对着庭院的落地玻璃立面上倒映着纵横交织的树枝。这座庭院不仅提供了隐私空间,并将阳光引入建筑的中心,同时它还能过滤掉街道发出的噪音。 a courtyard on two levels sits in the center of this semi-detached residence in singapore. designed by HYLA architects, the first level of the property is articulated around a frangipani tree that sits in the middle of a pond framed by a timber clad box. the home’s second storey lies over the dining area and in front of the master bedroom, while the full height glass façade facing the courtyard is screened by interlocking vertical and horizontal timber members. the courtyard not only offers privacy as well as letting in light into the center of the house, bu also acts as a buffer against noise emanating from the passing street.
a frangipani tree sits in the middle of a pond, framed by a timber clad box/鸡蛋花树位于由木结构盒子构成的池子中央image © derekswalwell
living accommodation is organized around the indoor greenery/居住空间围绕着这一室内绿色空间而建。image © derekswalwell
retractable panels allow fresh air to ventilate the home/可开启的窗板让新鲜空气进入室内。image © derekswalwell
the property is surrounded by areas of planted vegetation/这个建筑被周边的绿色植物环抱。image © derekswalwell
the vertical courtyard rises upwards/竖向庭院升入上层。images © derekswalwell
living accommodation/居住空间。image © derekswalwell
an area for private study/学习空间。image © derekswalwell
sleeping quarters/卧室。image © derekswalwell
greenery is also included throughout the bathroom/绿色空间同样也被置于浴室。image © derekswalwell
the white external façade presented to the passing street /白色的外墙面向街道。images © derekswalwell
出处:本文译自www.archdaily.com/,转载请注明出处。 |
来自专筑编辑尉东颖,vigo的报道。一个两层的庭院空间坐落在新加坡这座半独立住宅的中心。在HYLA建筑事务所的设计下,院落的第一层围绕一棵种植在以木质框架围合成盒装的中庭中心的鸡蛋花树展开。住宅的第二层位于餐饮空间之上、主卧室的前方,同时面对着庭院的落地玻璃立面上倒映着纵横交织的树枝。这座庭院不仅提供了隐私空间,并将阳光引入建筑的中心,同时它还能过滤掉街道发出的噪音。 a courtyard on two levels sits in the center of this semi-detached residence in singapore. designed by HYLA architects, the first level of the property is articulated around a frangipani tree that sits in the middle of a pond framed by a timber clad box. the home’s second storey lies over the dining area and in front of the master bedroom, while the full height glass façade facing the courtyard is screened by interlocking vertical and horizontal timber members. the courtyard not only offers privacy as well as letting in light into the center of the house, bu also acts as a buffer against noise emanating from the passing street.
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
Tubakuba Mountain 小型别墅概况:徘徊城市之上,躲藏在卑尔根最著名山脉的树林后;通过一条隧道,你可以进入一个木制的梦幻泡泡内,享受只属于你和你的孩子们的梦幻之夜。这个项目是卑尔根建筑学院的Espen Folgerø ——同时也隶属OPA 建筑事务所,所领衔的建筑设计工作室设计的。
只看楼主 我来说两句 抢板凳回复 举报
