土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 赏析SH住宅的设计风格
赏析SH住宅的设计风格
发布于:2015-05-30 08:42:30 来自:建筑设计/居住建筑设计 [复制转发]
© Aryeh Kornfeld
SH住宅位于智利圣地亚哥靠近安第斯山脉,基址由小山丘组成,四周环山。住宅利用这种地形条件,在不同方向都有良好的景观视野。
From the architect. SH house is located in Santiago de Chile close to Los Andes range, the area is composed of small rolling hills that are surrounded by mountains. The house takes this condition to frame views in several directions.
© Aryeh Kornfeld
平面图/Floor Plan
基地拥有1000平方米的区域,地形高差达4.5米。这个项目主要的挑战是如何将房子自身结构和远处景观进行整合。为达到此目的,采用石墙可以在不同高度形成不同的庭院。
The lot has 1.000 sq meter area, with a difference of level that reaches 4.5 meters high. The main challenge was to achieve the integration of both immediate and distant landscape with house own programs. To this end stone walls, allowed the formation of different courtyards in different heights.
© Aryeh Kornfeld
这个房子是建造在斜坡上的单一体量。在第一个庭院的入口处设置了一个小池塘和几面用于旧铁路线的旧木材建成的墙。
The House appropriates the slope through single volume. At the entrance the first patio is organized by a small pond and a series of walls of ancient woods used on the railway lines.
© Aryeh Kornfeld
厨房位于基地的南面,被两个庭院包围,这样可以形成交叉通风,并且把光线引入供儿童游戏的地下室。
The kitchen is located at the south of the lot and it is surrounded by two small patios that makes cross ventilation possible and give light to the basement, were children play room is located.
剖面图/Section
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
卧室和私密区位于一个混凝土体量中,其长达20米跨越主庭院且没有支撑结构,下面,起居室和餐厅被大型玻璃窗包围,当打开窗户的时候其室内可以和主庭院以及小池塘融为一体。
The bedrooms and privet areas are located in within a concrete volume that develops a 20mts span over the main courtyard without structural supports, under it, the living and dining areas are located surrounded by a large window that opens completely allowing integration with the main patio and the pool.
© Aryeh Kornfeld
烧烤区设置在起居室和游戏室之间的开放空间,从这里可以通过大理石台阶进入更高的庭院。房间通过混凝土体量东边的平台连接到这个区域。该建筑使用的材料主要是混凝土、石材、木材和玻璃。
The barbecue is located in an open space between the living room and a game room, ,from here is possible to access to the higher courtyard through a travertine marble staircase. The rooms are connected to this area by a terrace at the east of the concrete volume. The materials used are concrete, stone, carob wood and glass primarily.
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
平面图/Floor Plan
立面图/Elevation
立面图/Elevation
剖面图/Section
© Aryeh Kornfeld
建筑设计: 01ARQ
项目位置:智利,圣地亚哥都市区,巴恩斯特珀尔
面积:674.0平方米
建筑摄影:Aryeh Kornfeld
Architects: 01ARQ
Location: La Dehesa, Lo Barnechea, Región Metropolitana de Santiago , Chile
Area: 674.0 sqm
Photographs: Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
平面图/Floor Plan
© Aryeh Kornfeld
© Aryeh Kornfeld
剖面图/Section
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
© Aryeh Kornfeld
平面图/Floor Plan
立面图/Elevation
立面图/Elevation
剖面图/Section
© Aryeh Kornfeld
建筑设计: 01ARQ
面积:674.0平方米
建筑摄影:Aryeh Kornfeld
Architects: 01ARQ
Area: 674.0 sqm
居住建筑设计
28.74 万条内容 · 423 人订阅
Z-方形住宅的设计理念
© Henrietta Williams 这座遵循可持续原则由马厩改建而成的房子,坐落在南都柏林一个爱德华时代风格大型住宅的后花园中一块13mx13m的正方形地块上。From the architect. This mews house built on sustainable principles is located on a square (13.0 x 13.0 m) site in the rere garden of a large Edwardian house in South Dublin.
