image © rick brazil
与它周边的欧式风格建筑相对比,这座由当地事务所kendle design collaborative所设计的沙漠之翼住宅,呈现出一个由索诺兰沙漠的基地特殊情况而派生出来的设计。厚实地夯出来的土墙从发掘出来的土壤和混凝土分割块中铸就出来,形成了拥有直接视线和隐私性的多种多样的空间,并使用了土壤的质量来吸收热量,使白天之中的热量阻挡在室内空间之外,同时在寒冷的沙漠夜晚中释放出来。这个带角度的出挑屋檐结构用细长的钢柱子支撑在外部墙体的高度之上,并围绕着每一个内部空间开了狭长的天窗。深悬的屋顶使得全玻璃幕墙得以实现,并朝向地形和半私密庭院开启。 contrasting its european-style neighbors, the desert wing by local practice kendle design collaborative erects a design derived by the particular conditions of the site on the sonoran desert. thick rammed earth walls cast from the excavated dirt and concrete partitions form various rooms with directed views and privacy, using their mass to absorb heat, repelling it from the inside during the day while releasing it during the cold desert nights. the angular canopy structure is suspended above the height of the exterior walls on slender steel columns opening thin clerestory windows surrounding each interior space. the deep overhang of the roof allows for full glass walls that open up onto the landscape and semi-private courtyards. ![]()
image © rick brazil
image © rick brazil
image © rick brazil
室外的无边界泳池延伸了室内的空间感/outdoor infinity pool extends the interior space. image © rick brazil
image © rick brazil
image © rick brazil
室外露台由铜色钢管栅栏围合/exterior patio surrounded by a corten steel tube fence. image © rick brazil
image © rick brazil
前门/front entrance. image © rick brazil
前厅/front entry. image © rick brazil
前厅及主起居室/central living space and front entry. image © rick brazil
起居室/living room. image © rick brazil
厨房/kitchen. image © rick brazil
餐厅/dining room. image © rick brazil
image © rick brazil
主卧室/master bedroom. image © rick brazil
墙细节/wall detail
内部庭院/interior courtyard
image © rick brazil
image © rick brazil
项目信息 建筑设计:kendle design collaborative 室内设计:jack wozniak, 加州 棕榈泉 摄影师:rick brazil, 亚利桑那 prescott 位置:亚利桑那scottsdale 面积:8300平方英尺 project info: architects: kendle design collaborative interior designer: jack wozniak, palm springs, ca photography: rick brazil, prescott, az location: scottsdale, arizona size: 8300 square feet all images courtesy of kendle design collaborative |
image © rick brazil
来自专筑编辑尉东颖,vigo的报道。与它周边的欧式风格建筑相对比,这座由当地事务所kendle design collaborative所设计的沙漠之翼住宅,呈现出一个由索诺兰沙漠的基地特殊情况而派生出来的设计。厚实地夯出来的土墙从发掘出来的土壤和混凝土分割块中铸就出来,形成了拥有直接视线和隐私性的多种多样的空间,并使用了土壤的质量来吸收热量,使白天之中的热量阻挡在室内空间之外,同时在寒冷的沙漠夜晚中释放出来。这个带角度的出挑屋檐结构用细长的钢柱子支撑在外部墙体的高度之上,并围绕着每一个内部空间开了狭长的天窗。深悬的屋顶使得全玻璃幕墙得以实现,并朝向地形和半私密庭院开启。 contrasting its european-style neighbors, the desert wing by local practice kendle design collaborative erects a design derived by the particular conditions of the site on the sonoran desert. thick rammed earth walls cast from the excavated dirt and concrete partitions form various rooms with directed views and privacy, using their mass to absorb heat, repelling it from the inside during the day while releasing it during the cold desert nights. the angular canopy structure is suspended above the height of the exterior walls on slender steel columns opening thin clerestory windows surrounding each interior space. the deep overhang of the roof allows for full glass walls that open up onto the landscape and semi-private courtyards. ![]()
image © rick brazil
image © rick brazil
image © rick brazil
image © rick brazil
image © rick brazil
image © rick brazil
image © rick brazil
墙细节/wall detail
image © rick brazil
image © rick brazil
1人已打赏
居住建筑设计
返回版块28.74 万条内容 · 423 人订阅
赏析殖民地风格的庄园别墅Anticavilla Hotel酒店是一栋殖民地风格的庄园别墅,靠近库埃纳瓦卡中心,该酒店已经过大规模装修,创造出了迷人的位于美丽花园内的精品酒店,配有一个游泳池。这里还有一间意式餐厅、客房内有大型的当代艺术作品和舒心的温泉浴场。
只看楼主 我来说两句 抢板凳
