土木在线论坛 \ 暖通空调 \ 暖通制冷设备研发 \ 传质效率与什么有关?
传质效率与什么有关?
发布于:2007-10-20 18:38:20 来自:暖通空调/暖通制冷设备研发 [复制转发]
比如,风机盘管进出水12/7度,空调回风27度,假设露点温度为18度,那么盘管肯定会析出水分;
如果风机盘管进出水15/7度,空调回风27度,假设露点温度为18度,那么盘管也会析出水分;但是两者析出的水分的量肯定是不同的。我想问的是:这个传质过程,水分析出的量与什么有关?与盘管温度有关,是不是也和换热有驱动力(对数平均温差)一样,传质也取决于驱动力呢?
全部回复(63 )
  • qq_1479266612278
    好东西 感谢分享
    hffpw.weebly.com/
    zzfpw.weebly.com/
    ccfpw.weebly.com/
    jnfpw.weebly.com/
    kfpsh.weebly.com/
    xiandkfpw.weebly.com/
    ncfpw.weebly.com/
    tjfpw.weebly.com/
    nnfpw.weebly.com/
    whfpw.weebly.com/
    jndkfpw.weebly.com/
    kfpkm.weebly.com/
    cdfpz.weebly.com/
    wuxifpw.weebly.com/
    xianfpw.weebly.com/
    haerbfpw.weebly.com/
    njdkfpw.weebly.com/
    nbdkfpw.weebly.com/
    kmfpz.weebly.com/
    kfphz.weebly.com/
    nanjingfpw.weebly.com/
    cqsfz.weebly.com/
    sfcqsf.weebly.com/
    kfpncz.weebly.com/
    cdzzsfpw.weebly.com/
    kfpbj.weebly.com/
    cqdkfpw.weebly.com/
    cskfpz.weebly.com/
    jnzzsfpw.weebly.com/
    hzzzsfpw.weebly.com/
    nnzzsfpw.weebly.com/
    njzzsfpw.weebly.com/
    dkfpnt.weebly.com/
    ntkfpz.weebly.com/
    wxkfpz.weebly.com/
    dkfpts.weebly.com/
    dkfphz.weebly.com/
    szcyfp.weebly.com/
    bjkcyfp.weebly.com/
    shzzsfp.weebly.com/
    szzzsfp.weebly.com/
    cqzzsfp.weebly.com/
    ccdkfpw.weebly.com/
    sydkfpw.weebly.com/
    szdkfpw.weebly.com/
    jnkfpz.weebly.com/
    szkfpw.weebly.com/
    shkfpz.weebly.com/
    nnkfpgw.weebly.com/
    gzkfpgw.weebly.com/
    tjkfpgw.weebly.com/
    fzkfpgw.weebly.com/
    zzkfpgw.weebly.com/
    qddkfpz.weebly.com/
    hfkfpgw.weebly.com/
    zhkfpgw.weebly.com/
    kfpxm.weebly.com/
    kfpxmw.weebly.com/
    2017-05-21 17:26:21
  • wz250
    wz250 板凳
    看到你们的讨论问题,其实呢,也不是大的问题所在,同一台风盘,同一个房间,不管是什么水流速,风流量,它所传导的介质应该是一样的
    只是和时间有关
    2008-07-06 14:52:06
暖通制冷设备研发
1.63 万条内容 · 236 人订阅
Free Cooling
最近看到有些外资品牌制冷空调设备制造商频频提到Free Cooling这个词。请了解的网友帮忙解释下怎么个Free法。多谢!
