土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 中国设计师王耀华设计的阿姆斯特丹步行桥
中国设计师王耀华设计的阿姆斯特丹步行桥
发布于:2015-04-12 15:15:12 来自:建筑设计/公共建筑设计 [复制转发]
中国设计师王耀华设计的阿姆斯特丹步行桥
本文由设计师王耀华授权gooood发行。
Appreciation towards Yaohua Wang Architecture for providing the following description:
阿姆斯特丹步行桥位于荷兰的Amstel河上, 相邻Hermitage Amsterdam博物馆. 桥的功能包括了一条自行
车道, 一条人行道, 咖啡店, 自行车停泊区域和办公室. 步行桥的设计试图延续和发展之前项目对于形式
和结构风格的探讨. 在这个项目中,使用环形的钢结构框架, 来达成桥的跨度上对于结构的要求. 同时这
种环形的结构也为形式创造了新的可能, 多个不同层次的表皮与环形的钢结构互相缠绕, 并且在互相缠绕
的过程中创造了开口和能源机械构件的连接点. 同时,步行桥的功能区, 如咖啡店, 自行车停泊区, 被这
些环形的层次包裹其中. 步行道和自行车道在主流线上互相分开, 只在被包裹的功能区中产生联系.
Architect: Yaohua Wang Architecture
Structural Engineer: Organization Group
Program: Pedestrian Bridge, Cafe, Office
Note: Design proposal
Amsterdam bridge iv is aware of the simple functionality and sculpture of a bridge.
Therefore, every part of this design contributes to the unique aesthetic as seen in the
spiral steel structure. The design includes two independent pathways, specifically for
pedestrians and bicyclists, that run parallel to each other through the bridge. These
pathways meet at the center of bridge, which behaves as the functional hub. This central
location provides a sheltered space in which a slower pace can be obtained contrary to the
fast movement surrounding the bridge. Inside this hub, the elegant form of this bridge can
be appreciated.
F117 jet fighter plane is an very interesting example about the relationship between
performance and aesthetics. The unique form of F117 jet fighter plane came directly from the
need of hiding from radar wave, rather than from air dynamic aesthetics. The Amsterdam
bridge also tries to achieve this relationship. In this case, the idea is the relationship
between structural performance and aesthetic. The spiral structure provides an unique
structural ability, allows the bridge to span across the river, also allowing the tectonics
of several layers of spiral surfaces to interlock with each other. Meanwhile, these
interlocked surfaces and structures wrap around the function hub, provide shelter with
openings.
The solar and wind power plants are constantly feeding energy into the program for the
bridge. They reduce the bridge’s carbon footprint, also, they create a noise in its profile
line, making the bridge appear easier to blend into its urban context.
全部回复(11 )
  • yuyanhui63
    yuyanhui63 沙发
    很喜欢的建筑,多谢楼主!
    2016-04-30 18:10:30
  • 石大侠
    石大侠 板凳
    为啥你的帖子图片都打不开
    2016-04-30 13:00:30
公共建筑设计
51.18 万条内容 · 448 人订阅
南非建筑师 Peter Rich 的马篷古布韦展览中心(高清内外景...
