土木在线论坛 \ 电气工程 \ 照明工程 \ DIALux 4.402版最新功能说明
DIALux 4.402版最新功能说明
发布于:2007-10-20 11:07:20 来自:电气工程/照明工程 [复制转发]
Dear DIALux users
Once again we have some important information about DIALux.
DIALux 4.4.0.2
The new version of DIALux is available immediately as a download. You will find an exact list of the modifications in the different versions under the rubric DIALux - Service ? Version history http://www.dial.de/CMS/English/Articles/DIALux/Download/Versionshistorie.html?ID=63
Here are the most important points concerning the 4.4.0.1 und 4.4.0.2 versions:
Projects created using DIALux 4.4.0.0 used to cause problems when loading with the improved DIALux 4.4.0.1 version. This fault has now been remedied.
The import of all characters for DXF or DWG files is now possible through the inclusion of Unicode.
Any grid can be set for the output/printout. Even though the illuminance distribution is symmetrical, the display may be unsymmetrical if the grid is too small. Additional functionalities now prevent this problem.
When importing an ACIS SAT model, DIALux sometimes crashed when invalid material attributes were placed on the surfaces. This can now be prevented and the user must, if necessary, select the material once again in DIALux.
Optimization of the import and improved handling when positioning objects.
In the Swedish version the 搊pen file...?dialogue has been corrected.
New DIALux partner
Since our latest newsletter we are highly pleased to welcome the luminaire manufacturer Saudi Lighting from Riyadh (Saudi Arabia) as latest member at the DIALux project. Our new project partner affirmed DIALux once again as a world wide used and powerful lighting design tool. Also this new DIALux product catalogue will be available soon.
Dates of seminars
Would you like to use DIALux more effectively? We offer stimulating, practice-oriented seminars on all themes to do with lighting and building technology. You will find an overview of the venues, topics and languages in which these are offered under the following link: http://www.dial.de/CMS/English/Articles/Licht/Seminare/Seminare_Licht.html?ID=21
On our website www.dial.de you will find further useful tips about DIALux, lighting design and building technology.
If at any time you really get stuck or have a really good idea, then you can contact the DIAL hotline (German/English) free of charge under +49/(0)2351/1064-365 or hotline@DIALux.com. In the new menu 搊nline?you can contact us directly from DIALux.
Best wishes from L黡enscheid
Your DIALux team
  • lizijunxiaolijie
    英语太差,看的不是很明白!!
    2007-10-22 10:22:22
  • lxt9607
    lxt9607 板凳
    感谢斑竹的热心提示
    2007-10-22 09:37:22
照明工程
14.05 万条内容 · 453 人订阅
照明上的一点
应急照明和正常照明是两个变压器那这两根N线能并起来吗?
