土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 控制alert函数对话框显示的变量是什么?
发布于:2007-10-19 09:00:19 来自:建筑设计/CAD下载及教程 [复制转发]
我的不显示弹出对话框
奇怪了
全部回复(3 )
  • chuliuxiangcad
    应该是FILEDIA吧,要不就重新安装CAD吧!应该就会好的!
    2007-12-09 22:12:09
  • biechen
    biechen 板凳
    * What is QAFLAGS?
    QAFLAGS been used a long time (< r12) by deelopers and autodesk themself too.
    QAFLAGS acceps a alue between 0 and 32767
    bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard ).
    bit 1 (2) : no pause during text screen listings.
    bit 2 (4) : no "alert" dialogs (text display instead).
    bit 7 (128) : accepts "screen picks" (point lists) ia (command) function.
    Normally QAFLAGS should be set to 0. Because it might be set to other alues it is a good idea to put (setar "QAFLAGS" 0) in acaddoc.lsp or any other of your lisp files that you use for startup.
    2007-10-31 16:15:31
CAD下载及教程
52.09 万条内容 · 690 人订阅
求PDF2DWG的PJ
哪位任兄有这个工具软件的PJ文件或注册吗,请共享一下,先谢谢啦!
