土木在线论坛 \ 电气工程 \ 电气资料库 \ 三相异步电动机型号怎么看?
三相异步电动机型号怎么看?
发布于:2014-10-24 09:18:24 来自:电气工程/电气资料库 [复制转发]
比如说W250M-4表示什么意思?
电气资料库
70.19 万条内容 · 799 人订阅
求助 解题目 积分运算器
For the circuit above, the value of R=4MΩ and C=0.75 μF. v i( t)= t2V for 0s≤ t≤5s. What is the value of v o at time t=5s, if v o(0)=0? You can assume the operationalamplifier behaves as an ideal op amp with power supplies of +15V and −15V. Give your answer in volts, andomit the units from your answer.
