土木在线论坛 \ 建筑结构 \ 钢结构软件 \ Staad pro打印构件内力和支座反力的命令前面显示问号是怎么回事啊
发布于:2014-08-28 23:54:28 来自:建筑结构/钢结构软件 [复制转发]
有没有大神帮帮忙啊,是不是因为破解不成功的原因啊。
  • zjjhxyzt
    zjjhxyzt 沙发
    我也出现这个问题,最后计算结果位零
    2014-09-08 17:44:08
  • zly_397758902
    zly_397758902 板凳
    1. STAAD PLANE
    INPUT FILE: Example 1.STD
    2. START JOB INFORMATION
    3. ENGINEER DATE 28-AUG-14
    4. END JOB INFORMATION
    5. INPUT WIDTH 79
    6. UNIT FEET KIP
    7. JOINT COORDINATES
    8. 1 0 0 0; 2 30 0 0; 3 0 20 0; 4 10 20 0; 5 20 20 0; 6 30 20 0; 7 0 35 0
    9. 8 30 35 0; 9 7.5 35 0; 10 22.5 35 0; 11 15 35 0; 12 5 38 0; 13 25 38 0
    10. 14 10 41 0; 15 20 41 0; 16 15 44 0
    11. MEMBER INCIDENCES
    12. 1 1 3; 2 3 7; 3 2 6; 4 6 8; 5 3 4; 6 4 5; 7 5 6; 8 7 12; 9 12 14; 10 14 16
    13. 11 15 16; 12 13 15; 13 8 13; 14 9 12; 15 9 14; 16 11 14; 17 11 15; 18 10 15
    14. 19 10 13; 20 7 9; 21 9 11; 22 10 11; 23 8 10
    15. DEFINE PMEMBER
    16. 1 PMEMBER 1
    17. DEFINE MATERIAL START
    18. ISOTROPIC STEEL
    19. E 4.28151E+006
    20. POISSON 0.3
    21. DENSITY 0.489024
    22. ALPHA 1.2E-005
    23. DAMP 0.03
    24. END DEFINE MATERIAL
    25. MEMBER PROPERTY AMERICAN
    26. 1 3 4 TABLE ST W14X90
    27. 2 TABLE ST W10X49
    28. 5 TO 7 TABLE ST W21X50
    29. 8 TO 13 TABLE ST W18X35
    30. 14 TO 23 TABLE ST L40404
    31. CONSTANTS
    32. BETA 0 MEMB 2 5 16
    33. BETA 90 MEMB 3 4
    34. MATERIAL STEEL ALL
    35. MEMBER TRUSS
    36. 14 TO 23
    37. MEMBER RELEASE
    38. 5 START MZ
    39. UNIT INCHES KIP
    40. SUPPORTS
    STAAD PLANE -- PAGE NO. 2
    41. 1 FIXED
    42. 2 PINNED
    43. UNIT FEET KIP
    44. LOAD 1 LOADTYPE DEAD TITLE DLL
    45. JOINT LOAD
    46. 4 5 FY -15
    47. 11 FY -35
    48. MEMBER LOAD
    49. 8 TO 13 UNI Y -0.9
    50. 6 UNI GY -1.2
    51. LOAD 2 LOADTYPE WIND TITLE WL
    52. MEMBER LOAD
    53. 1 2 UNI GX 0.6
    54. 8 TO 10 UNI Y -1.
    55. LOAD COMB 3 COMBINATION LOAD CASE 3
    56. 1 0.75 2 0.75
    57. PERFORM ANALYSIS
    P R O B L E M S T A T I S T I C S
    NUMBER OF JOINTS/MEMBER+ELEMENTS/SUPPORTS = 16/ 23/ 2
    SOLVER USED IS THE OUT-OF-CORE BASIC SOLVER
    ORIGINAL/FINAL BAND-WIDTH= 5/ 4/ 15 DOF
    TOTAL PRIMARY LOAD CASES = 2, TOTAL DEGREES OF FREEDOM = 43
    SIZE OF STIFFNESS MATRIX = 1 DOUBLE KILO-WORDS
    REQRD/AVAIL. DISK SPACE = 12.0/ 219452.7 MB
    ZERO STIFFNESS IN DIRECTION 6 AT JOINT 9 EQN.NO. 21
    LOADS APPLIED OR DISTRIBUTED HERE FROM ELEMENTS WILL BE IGNORED.
    THIS MAY BE DUE TO ALL MEMBERS AT THIS JOINT BEING RELEASED OR
    EFFECTIVELY RELEASED IN THIS DIRECTION.
    ZERO STIFFNESS IN DIRECTION 6 AT JOINT 11 EQN.NO. 31
    ZERO STIFFNESS IN DIRECTION 6 AT JOINT 10 EQN.NO. 37
    58. LOAD LIST 1 3
    59. FINISH
    2014-08-28 23:56:28
钢结构软件
1.62 万条内容 · 196 人订阅
MSteel结构工具箱版本限制怎么解决啊
请问哪位大仙 我的MSteel结构工具箱使用一段时间后就受版本限制了
